Why Is There a Reaction Force in the Upper Pulley but Not in System 1?
The discussion revolves around the confusion regarding the presence of a reaction force in the upper pulley compared to system 1. Participants explore how the mechanics of the pulleys affect the forces at play, particularly the role of tension in the cords. It is noted that the vertical string from the lower pulley reduces the reaction force between the large block and the ground, facilitating movement. The relationship between tension and the normal force is emphasized, suggesting that with tension present, the normal force is reduced. Overall, the mechanics of the pulleys significantly influence the forces acting on the system.
jeremy222
m(1) is 20kg
m(2) is 30kg
gravity use 10
U static is .6
u kinetic is .4
Basically my professor gave the answer to the question in the link along with the picture. The only problem is that i am not sure he did case three right and i am after spending hoursl ooking at it i am not sure why there is a reaction force in the upper pulley and not in system 1. I am confused about how the systems are different and how that changes my answer.
Well i already had the answer with me so i just kept doing and trying to get the same answer but although i managed to get case 1 and 2 i don't know fi i should treat the pulleys as object or whatever else is necessary for the second system.
jeremy222 said:
m(1) is 20kg
m(2) is 30kg
gravity use 10
U static is .6
u kinetic is .4
I too was concerned with talk of reaction force from the upper pulley.
It looked to me that the vertical string would reduce the reaction force force between the big block and the ground, making it easier to move? (due to things happening at the LOWER pulley)
But how does the lower pulley effect everything else? I did a free body for the lower one but i don't know how that would concern the upper pulley
In Option B, there are two cords going up from the lower pulley, but only one thread going down from the upper pulley. Once you provide tension in the cord that indicates twice the upward force compared to the downward force [just considering effects of Tension] so I expect a net lifting force equal to the Tension.
With no tension, the (upward) Reaction Force will be equal to the (downward0 weight force of the two blocks.
With Tension, the sum of the (upward) Tension and Reaction force should equal the (downward) weight force, so the Normal force would be reduced?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
