Why is this matrix not working in my program?
That's why I decided to use a Vandermonde matrix in my code instead of inverse or Gauss-Jordan elimination. But I managed to solve the problem with that method in the end. In summary, the conversation discusses the use of a matrix and polynomial interpolation to solve a Project Euler problem. The code provided includes a function for calculating a polynomial, a loop to create a matrix, and a while loop to find the correct answer. The conversation also includes a discussion about the range function in Python and ways to debug code.
etotheipi
https://projecteuler.net/problem=101
Code:
import numpy as np
for j in range (1,11):
    M = np.empty([j, j])
    for x in range(1,j+1):
        for y in range(1,j+1):
            M[y,x] = y**(j-x)
    Minv = np.linalg.inv(M)
The ##j^{\mathrm{th}}## estimate ##\mathrm{OP}(j,n)## which fits ##j## data points is a ##(j-1)^{\mathrm{th}}## degree polynomial ##u^{(j)}(n) = a_{j-1} n^{j-1} + \dots + a_{0}## which agrees with ##u_n## on the set ##n \in \{1, \dots, j \}##, so$$\mathbf{a} := \begin{pmatrix} a_{j-1} \\ \vdots \\ a_0 \end{pmatrix} = \begin{pmatrix} 1 & 1 & \cdots & 1 \\ 2^{j-1} & 2^{j-2} & \cdots & 1 \\ \vdots & \vdots & & \vdots \\ j^{j-1} & j^{j-2} & \cdots & 1\end{pmatrix}^{-1} \begin{pmatrix} u_1 \\ \vdots \\ u_j \end{pmatrix} := \mathbf{M}^{-1} \mathbf{u}$$I need to make the matrix ##\mathbf{M}##, why does it not work?
Code:
M[y,x] = y**(j-x)
IndexError: index 1 is out of bounds for axis 0 with size 1
Technology news on Phys.org
For the M[x,y] assignment do you mean M[x-1,y-1] ?
Likes etotheipi
oh yeah that's it thanks :smile:
It does not give me the correct answer :frown:
Python:
import numpy as np
sum = 0
def p(k):
    s = 0
    for i in range(0,11):
        s += ((-1)**i)*(k**i)
    return s
    M = np.empty(shape=(j,j))
            M[y-1,x-1] = y**(j-x)
    U = np.empty(shape=(j,1))
    for i in range(1, j+1):
        U[i-1] = p(i)
    A = np.matmul(Minv, U)
    z = 1
    FIT_found = False
    while(FIT_found == False):
        estimate = 0
        for r in range(0,j):
            estimate += A[r]*z**r
        if(estimate != p(z)):
            sum += estimate
            FIT_found = True
        else:
            z = z + 1
print(sum)
I think the idea of doing Project Euler problems is to work on your code until it does :smile:
When posting code here it helps if you add the language so syntax highlighting works:
Python:
import numpy as np
sum = 0
def p(k):
    s = 0
    return s
        U[i-1] = p(i)
    z = 1
    FIT_found = False
        estimate = 0
            sum += estimate
            FIT_found = True
        else:
            z = z + 1
print(sum)
Likes etotheipi
I always get confused by Python's range() function: note that range(1, 11) gives you [1, 2, 3, 4, 5, 6, 7, 8, 9, 10]: this is the first thing I'd check.
And then i'd check that my j, x, and y values are doing what I want in the inner loop (either with an IDE or a simple print statement).
Edit: first of all I'd refactor it so all my loops start at 0, it makes it much easier to keep track.
Likes etotheipi
thanks okay I'm going to finish this tomorrow because I have homework and my stupid code is giving me -670.99996864
  • Haha
Likes pbuk
:eek: yeah, I don't think that's right.
That’s how I checked the code. I called that seldom used secret programmers function:
Python:
print(‘j = %d, x = %d, y = %d’%(j,x,y))
just before his M assignment.
I'd look for a simpler method of polynomial interpolation if I were you.
