Albeaver89
- 18
- 0
This isn't a homework question, but I felt it was appropriate...
Proof that √(x^2)/x=sin(x)
Albeaver89 said:This isn't a homework question, but I felt it was appropriate...
I think that should be:Albeaver89 said:This isn't a homework question, but I felt it was appropriate...
SammyS said:I think that should be:
\displaystyle \frac{\sqrt{x^2}}{x}=\text{sign}(x)\ .
Albeaver89 said:Sorry that's what I thought i had...my bad![]()
No for a couple of reasons. First, the OP meant sign(x) not sin(x). Second,lendav_rott said:Oh nevermind, so basically 1 = sinx .
No. x ≠ ##\sqrt{x^2}##lendav_rott said:So x = arcsin 1
What is really amasing is how they waste the ink to write X as sqrt(x²)
lendav_rott said:Unless there's something hidden here, I cannot see the point.
Well sin X = 1 if X is Pi and the way that the sine's sinusoidal graph repeats itself you can get the other possibilities for X.
Yes, that's exactly what I mean. As an example, do you think that ##\sqrt{(-2)^2} = -2##?lendav_rott said:Wait, x =/= sqrt(x²)??
No, I don't mean that either. The square root of a nonnegative expression produces a single value, not two of them, as ± x implies.lendav_rott said:I cannot see what you are trying to say - do you mean that sqrt(x²) = +/- X?
Your lecturer is correct.lendav_rott said:This is actually something I was arguing over with my math's lector and he said that the square root of X or X² for that matter, is defined as sqrt(X²) = |X|
Also, your second step isn't valid if A ≤ 0, because ln(A) wouldn't be defined.lendav_rott said:And after thinking about it, i thought about
A^x = B
x lnA = lnB
if B were negative then this wouldn't hold true and the only explanation is that Sqrt(A²) = |A|
