vcsharp2003
- 897
- 177
- Homework Statement
- For the question as in screenshot, explain why the optical pyrometer gives a too low reading.
- Relevant Equations
- ##\frac {\Delta Q} {\Delta t} = \epsilon \sigma A T^4## where ##\epsilon## is emissivity of the body at temperature ##T## having a surface area of A and ##\sigma## is a constant for all bodies called Stefan Boltzmann constant..
From my knowledge, the optical pyrometer determines temperature of a body based on the visible part of the heat radiation spectrum emitted by a body. Now the iron piece was red hot inside the furnace as well as outside the furnace, so it is emitting heat radiation in the visible part both while in and out of the furnace. My only guess is that when red hot iron piece is outside, the heat radiation in the visible part of light becomes very small as compared to when it was inside the furnace, and so the optical pyrometer senses a too low temperature of the iron piece outside the furnace.
If above explanation is correct then I still don't understand why the visible part of the heat radiation spectrum becomes very less when iron body is placed outside the furnace, even though it's still red hot outside.
