Why parts of the laser ray seem brighter than other parts
Laser rays appear brighter in certain areas due to variations in the density of particles, such as dust or fog, in the air, which scatter the light. The perceived movement and fractures in the beam are also influenced by these particles, as they reflect and refract the light. In a vacuum, the laser beam would not be visible because there are no particles to scatter the light. Observations of laser beams in different environments, such as using smoke or fog, enhance visibility and create the desired effects. Understanding these principles is crucial in applications like film production and concerts.
titansarus
Hi.
When we see a laser ray, it seems that part of the ray are brighter than the other parts and they seem like they’re vibrating and moving. It also seems there are fractures in its path. I want to know why do we see like this?
For example see this picture (it is from wikipedia). I circled some parts with pink. Why some of these parts are brighter than the others? And it seems there are fractures in its path (the rightmost circled one). Is it because of the procedure of making laser (stimulating) and that it is not a completely constant procedure in atomic scale?
Sorry for my English and thanks in advance.
Science news on Phys.org
probably differing amounts of dust in the air
The only reason you are seeing the beams at all is that a colloidal dispersion (smoke, vapor (fog), or dust) is being used.
In the photo above, most beams are saturating the image - so variations in their intensity will not be rendered.
For the weaker beams, there are variations in the density of the fog.
titansarus said:
When we see a laser ray,...
... there must something in its way.
You mean in vacuum you won't see the polarized beam at all. How can we test that here on earth?
P.S. (restatement of the first part): that means in vacuum you won't see the polarized beam at all.
You would see it, if it hits your eye.
Or see the dot when it hits an object. (My original statement (the first part) was not a question.)
About the 2nd part: we can use a vacuum airtight glass tube and let the laser cross it. I just tried and it works. No beam inside.
[Or we can observe the beam changes for dimmer and dimmer air ... . That kind of explains (/is related to) also the original question:]
You've heard, maybe, of vacuum chambers?
You're late!
Stavros Kiri said:
You're late!
Yeah, not paying enough attention.
Don't we all ... sometimes
This. Light always* travels in completely straight lines. For you to see the laser "beam" from the side, the light has to bounce off of something, like moisture or a speck of dust.
In film production, or at concerts, they will often use lasers in combination with dry-ice smoke machines and/or smoke from pyrotechnics to create the affect of a beam going through the air.
*(I don't know what happens to light when near black holes or other cosmic disturbances)
