Why positive PR is the better than negative PR in VLSI
Positive photoresists (PR) have largely replaced negative PR in VLSI fabrication due to their superior process controllability, especially for small geometry features. This shift is attributed to the increasing density of integrated circuits, which allows for more transistors in a given die area. The Rayleigh criterion indicates that positive PR provides better resolution, essential for achieving finer details in modern semiconductor manufacturing. As a result, positive PR is now the dominant choice in the industry. Understanding these advantages is crucial for advancements in VLSI technology.
empkth
As attached, I know basic concept between Positive and Negative PR
But, I confirm this message; Negative resists were popular in the early history of integrated circuit processing, but positive resist gradually became more widely used since they offer better process controllability for small geometry features. Positive resists are now the dominant type of resist used in VLSI fabrication process.
1. Why Positive PR is the better than negative PR in VLSI?
2. Why Positive PR is the better than negative PR about "Resolution" ?
R=K*λ/NA (Rayleigh criterion)
Please.. Answer to me, I'm so curiosity... with Engineertic answer..
Hi
welcome to PF
Negative resists were popular in the early days of integrated circuit processing. Positive resist slowly became more widely used since they offer better process control for small geometry features as dies became higher density. Positive resists are now the main type of resist used in VLSI fabrication processes.
Dave
Thanks to Dave!
But What is the meaning of higher density? So, higher density... After what?
Please.. Add to logical answer.
higher density = more transistors etc in a given area of the die
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
