Why satellite needed to launched in prescribed height and orbit
Satellites are launched into specific orbits based on their intended functions, with sun-synchronous orbits favored for mapping to ensure consistent revisit times. Geostationary orbits are ideal for communication and certain weather satellites, maintaining a constant position over the same area. Molnyia orbits, with a semi-synchronous 12-hour period, are used for polar coverage, particularly by countries with challenging geostationary access. Higher orbits reduce atmospheric drag, extending satellite lifespan but increasing launch costs and decreasing sensor resolution. The choice of orbit ultimately depends on the satellite's mission requirements.
dijinj
What are the reasons for satellite to be launched to outer atmospheric orbits... Is reduction in air friction a major reason, or is it just an added advantage. I know escape velocity has Major reason in it , what are other major reason for chosing particular orbit for a sate
It depends on what you want the satellite to do:
  • If you want to do mapping work, you will almost always use a sun-synchronous orbit, going over the poles within a fairly low and narrow altitude range, which gives you the ability to revisit areas at the same time of day every day.
  • If you want to keep your satellite over the same patch of ground at all times, you need a geostationary orbit, taking 24 hours to complete an orbit. Perfect for communication satellites, but also used for certain weather satellites that give you a picture of more than a third of the planet at once.
  • Molnyia or tundra orbits are somewhat odd orbit in that they are semi-synchronous, i.e. they have a 12 hour period. They’re usually highly inclined as well to put their high points up over the polar regions. Originally pioneered by the USSR for their civilian communications satellites since it was both too difficult for them to achieve a proper geostationary orbit and because they are so far north that having a geostationary satellite is wasteful due to poor polar coverage.
  • Mid-level orbits are used mostly for navigation satellites. GPS, GLONASS, Galileo, Beidu.
The higher the orbit, the lower the drag, and therefore the longer the expected service life without reboost. But they’re also more costly to access for a given payload mass, and provide lower sensor resolution for mapping work.
Likes russ_watters, Klystron, berkeman and 3 others
Thank you
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
25K
