Why Sun Rays Lose Heat in Space: Examining the Unknown
Sun rays lose heat as they travel through space primarily due to the decrease in their density, or flux, as they diverge in all directions. The intensity of sunlight diminishes with distance; at double the distance from the sun, the number of rays reaching a given area is reduced to a quarter. The concept of temperature does not apply to individual rays, as heat is experienced from the collective density of rays. Space, while often referred to as a void, does possess properties such as volume and geometry, allowing for the movement of objects. Additionally, cinematic portrayals of space exposure, such as a head shattering in vacuum, are exaggerated and not scientifically accurate.
kalidas1992
Why sun rays are not considerably hot when reaching earth..? is there any specific reason for the sun rays to lose its potential(temperature) as it travels a long distance in space where there is no forces to contain it nor disturb its motion. Does space have property too,because as far as i know space is a VOID
Astronomy news on Phys.org
The concept of temperature does not apply to individual rays.
The heat you experience off sunlight comes from the density of the rays (we'd say "flux") rather than from individual rays. Since the rays diverge in all directions, the density of the rays (the number that pass through each square meter) decreases with distance from the sun. At double the distance, the number of rays is quartered.
But we need to be careful - the word "ray" has a specific definition in science and I am not sure that is the definition you are using.
I don't know what you mean by "does space have property" ... and I'm not sure that "void" is a precise term ...
Are you asking about the classical vacuum?
There is a sense in which we can talk about the properties of empty space - you have been doing that as soon as you say it is empty ... which suggests it has the property of volume. Things can travel in it - so it has to have an extent and a geometry ... we can discover the geometry by tracing trajectories just like we discover the geometry of the surface of the Earth. It's a big subject ... so the short answer is "yes: it makes sense to talk about space having properties".
Likes 1 person
Thank you san for clearing my doubt. I have seen in a film featuring a scene when a astronomer opens his space helmet off his head his head getting shattered into tiny pieces. Does that makes sense or is that what really happens?
No. The moviemakers were using artistic license. You'll see other movies where other things happen.
This is a different topic - you can google for what happens when the body is exposed to hard vacuum.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
