Why the frequency in both shallower and deeper part is the same?
  • Thread starter Thread starter ppt
    Frequency
The discussion focuses on why the frequency of water waves remains constant in both shallower and deeper areas despite changes in wavelength. It explains that when a wave is produced, refraction occurs, but the frequency remains unchanged to prevent energy loss or gain at the boundary. The relationship between wave energy and frequency is highlighted, noting that energy is proportional to frequency, which supports the conclusion of constant frequency. Additionally, Maxwell's equations dictate that the electric field must be continuous across boundaries, further enforcing the idea that frequency does not change. This understanding is crucial for comprehending wave behavior in different depths of water.
ppt
Use water waves as examples.
Put something in the water. When you produce a wave, refraction will occur on above the 'something'.
But why the frequency in both shallower and deeper part is the same?
In addition, the wavelength in the shallower part reduce. Does this means the engery of the wave increase?
The energy of the photons that comprise the wave is proportional to their frequency. If there were a frequency change at an interface, this would mean energy is being gained or lost at the boundary. Since this is not observed to happen, we conclude that the frequency does not change.
A more quantitative reason is imposed by Maxwell's equations. Maxwell's equations in optical media demand that the electric field be continuous over the boundary for all time. This is only possible if the frequency of the wave does not change.
Claude.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
