- #71
Sturk200
- 168
- 17
DaleSpam said:Sorry, I was not very pleased with my previous post and tried to delete it to make my objection to your reasoning clear, but you were too fast and had already responded
The pratfalls of instantaneous communication!
DaleSpam said:The objection is that you are applying a double-standard by NOT asking for the mechanism behind Euclidean geometry. Do you not see the clear inconsistency in your position? In your own words you accept Euclidean geometry with no mechanistic explanation simply "because I already believe", but you require such an explanation of Lorentzian geometry.
Let me see if I can try to clear this up. I do not ask for a mechanism for any geometrical procedure -- geometry is geometry and does not require forces. What I "already believe" is not that Euclidean geometry requires no mechanism, but rather that objects in the real world are constituted by their lengths and durations, both of which features happen to be preserved by a Euclidean rotation, neither of which are preserved by a Minkowski rotation.
My gripe, then, is not mathematical or geometrical. Rather, it is ontological. The battle between Euclid and Minkowski is really over the question of what constitutes an object -- is it length and duration or is it the space-time interval? By explaining, for instance, length contraction using a Minkowski rotation, and insisting that this geometrical explanation is the full physical explanation, we are awarding ontological priority to the space-time interval. This, again, is because the rotation does not invoke a mechanism (therefore does not change the underlying object), and yet alters the length and duration of an event.
What grounds have we for awarding ontological priority to the space-time interval? Simply that the speed of light is constant (on which the entire theory is based). Might we find a non-geometrical explanation of length contraction by further inquiring as to why the speed of light is constant? My contention, considering how little was known about the composition of matter in Einstein's day as compared with our own, is that we might. And apparently I am not alone in this hope (http://www.euregiogymnasium.ch/alumni/images/pdf/aeneas_wiener-lorentz_contraction.pdf). The idea is that the physical reason for the constancy of the speed of light may also explain length contraction without invoking space-time geometry.
DaleSpam said:I believe that there is a mechanism (per your definition) which explains the geometry of spacetime in relativity.
Is this not going to get you in trouble when I ask you, in the interest of consistency, to provide a mechanism for Euclidean geometry?
DaleSpam said:Flat spacetime is the solution of the EFE in the special case where there is no significant mass present.
My understanding is that special relativity was "written in" to the EFE, but I probably don't know enough about GR yet to hold my own.
