Why there are summer and winter seasons?
  • Thread starter Thread starter Hectix
    Seasons Summer
The four seasons are primarily caused by the Earth's axial tilt rather than its elliptical orbit. In the northern hemisphere, winter begins as the Earth reaches perihelion, while summer occurs during aphelion. The axial tilt results in extreme variations in daylight, particularly at the poles, where summer features continuous daylight and winter has prolonged darkness. Although the Earth's orbit is slightly elliptical, its impact on seasonal temperature is minimal compared to the effects of axial tilt. Understanding these factors clarifies why seasons repeat consistently each year.
Hectix
Hello guys, can someone explain me the four seasons ? Why they repeat in same intervals every year ? I think of this:
Thanks
Astronomy news on Phys.org
ThanksView attachment 93000
That picture is not the reason for the seasons (at least, not the whole story).
In fact, in the northern hemisphere, winter is just getting started when the Earth passes thru the perihelion (closest approach to the sun), somewhere along about January 3 or so. When summer is at its height in July in the northern hemisphere, the Earth is passing thru its aphelion (farthest point away from the sun). What is this sorcery?
https://en.wikipedia.org/wiki/Perihelion_and_aphelion
It's explained here:
https://en.wikipedia.org/wiki/Season
Thanks
As you suggested, the Earth's orbit is not perfectly circular, but it's not as an extreme elipse as your diagram suggests.
While that does make some difference to the overall amount of solar radiation arriving on Earth, that effect is vastly less than the effect produced by the Earth's axial tilt.
The effect of the axial tilt is such that in the northern hemisphere, 'Summer' in the polar regions is 6 months of continuous daylight, and winter is 6 months of darkness.
The same thing happens at the South pole, but the opposite way around, Summer in the northern hemisphere is winter in the south.
Outside of the polar regions there are longer days in summer, but the Sun does set for a while every day.
The orbital eccentricity of the Earth is about 0.017, which means that the Earth's max. and min distances from the sun differ by about 5 million km (out of about 150 million km average distance)
https://en.wikipedia.org/wiki/Earth
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
