LaTeX Why this LaTeX typing doesn't display?
  • Thread starter Thread starter mcastillo356
    Latex
The discussion centers on issues with LaTeX formatting in a specific post regarding the integral of the cosecant function. The main problem identified is that mixing BBCode (like color formatting from a dropdown menu) with LaTeX commands leads to rendering errors. Users are advised to use LaTeX commands explicitly for colors and to avoid unnecessary braces around function arguments and simple fractions. It is emphasized that focusing on clear wording is more important than intricate formatting, as complex features may hinder accessibility and reliability in rendering. Overall, the conversation highlights best practices for using LaTeX in forum posts to ensure proper display and comprehension.
mcastillo356
Hi PF
I've been for a while taking a glance to recent posts of mine, in search for right or wrong LaTeX performance; everything correct, except for this thread:
https://www.physicsforums.com/threa...n-understanding-different-approaches.1056106/
The following typing has not worked
$$=\frac{1}{2}\ln{|u-1|}-\frac{1}{2}\ln{|u+1|}$$
Where is the mistake?
Regards
What equals?
  • Love
Likes mcastillo356
$$x=\frac{1}{2}\ln{|u-1|}-\frac{1}{2}\ln{|u+1|}$$
Likes mcastillo356
mcastillo356 said:
Hi PF
Regards
You cannot use colors in formulas.
Likes mcastillo356
One can use colours in a formula, provided one states it explicitly using the ##\rm{LaTeX}## command, rather than choose a different colour for some part of the formula only from the drop down menu that's available in physicsforum's writing space.
For example : I can correctly type ##a\color{red}{+}b.\quad## I typed ##\quad\texttt{##a\color{red}{+}b}##.##
Try writing the same choosing the + only in red from the drop-down color menu here and you'd get incoherent compiling from the editor. I don't know why it happens though.
Let me do it here to the right. ##a+b##.
See what I got above. 👆🤷‍♂️. It didn't compile and the LaTeX math declarations are visible!
Of course if you don't use ##\rm{LaTeX}## for it, you're fine. For instance, (a+b) comes out alright.
I would encourage you not use the fanciest of features:
  1. They are less tested and therefore more likely to break
  2. They may make the message less accessible to the visually impaired
  3. It usually is better to spend more time formulating the words of your post that formatting of the equations.
Likes mcastillo356 and berkeman
LaTeX rendering is an optional extension of the software. I doubt that standard UI elements - such as those for text formatting - have been modified to parse the entire draft in order to determine whether they should be inserting phpBB or LaTeX commands in the particular case.
This works:
$$=\frac{1}{2}\ln|u-1|-\frac{1}{2}\ln|u +1|$$
Mixing BBCode (for example [ COLOR]) in LaTeX expressions fouls up the LaTeX rendering.
Incidentally, for simple fractions like 1/2 you don't need to use braces around each digit. By "simple" I mean each part is a single character. In other words, this will work \frac 1 2, but this won't \frac 1 10.
Also, don't use braces around function arguments. For example, use \ln(|x + 1|) or \ln|x + 1|but not \ln{|x + 1|}. The latter doesn't cause problems, but it's just extra cruft that you don't need to type.
The dropdown menu inserts BBCode markup, which doesn't play well with LaTeX.
Amen!
