Why we use strictly less than delta and epsilon in definition of limits
MarlyK
I'm wondering why we can't use less than or equal to for the formal definition of the limit of a function:
lim x→y f(x)=L iff For all ε>0 exists δ>0 such that abs(x-y)<δ implies abs(f(x) - L)<ε
Why not:
lim x→y f(x)=L iff For all ε>0 exists δ>0 such that abs(x-y)=<δ implies abs(f(x) - L)=<ε
I just imagine that it doesn't matter because epsilon is arbitrary, but I'm not sure. If we're using the epsilon such that we have a strict inequality, given that set of x that satisfies this, all we're doing is including the boundary points of the open set specified by delta on the domain, and we know that by the definition using strict inequalities that there then exists a [ε][/1]>ε such that abs(f(x) - L)<[ε][/1] (and thus abs(f(x) - L)=<[ε][/1], but we know that there are not x in our ball that actually satisfy abs(f(x) - L)=[ε][/1]).
But I can't seem to find a way to satisfy a two way implication i.e. prove the definitions are equivalent. Maybe there's a good contradiction up someone knows two show they're not equivalent?
The definitions are equivalent.
Suppose f satisfies the <= definition of \lim_{x \rightarrow y}f(x) = L. Let \epsilon &gt; 0. Then there exists \delta &gt; 0 such that 0 &lt; |x - y| \leq \delta implies |f(x) - L| \leq \epsilon/2. Thus clearly 0 &lt; |x - y| &lt; \delta also implies |f(x) - L| \leq \epsilon/2. But \epsilon/2 &lt; \epsilon, so f satisfies the < definition of \lim_{x \rightarrow y}f(x) = L.
You can prove the converse quite similarly.
Thanks - I was having trouble trying to find a way to imagine picking a larger epsilon while keeping it arbitrarily close to zero, but I see now that if we define the relation as a proportion of the smaller epsilon, this works. Thanks.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
