Why we won't notice anything special when crossing the horizon?
  • Thread starter maxverywell
  • Tags
    Horizon
In summary: Which is obviously not possible in the context of relativity.In summary, the concept of crossing the event horizon of a black hole is often misunderstood. While it is true that everything inside the event horizon moves only in one direction towards the singularity, this is also the case outside the horizon. The reason we don't notice anything special when crossing the event horizon is because it happens all the time in our everyday experiences. Additionally, the idea of "space and time switching roles" beyond the horizon is only true in certain coordinate systems and is not necessarily a physical reality. Finally, the experience of crossing the horizon and the behavior of objects within it can only be fully understood when
  • #106
PeterDonis said:
More precisely, if the proper acceleration required to "hover" at the radius, above the horizon, at which the robot starts being winched, redshifted to infinity, were 1 g. (This also assumes that the robot is winched up slowly enough that its motion can be approximated by a series of static states at gradually increasing radius, and that the distance through which the robot is winched is small enough that there is no detectable change in the redshifted proper acceleration.) No object can be winched up from the horizon itself, and the surface gravity is the redshifted proper acceleration at the horizon. The redshifted proper acceleration at any point above the horizon will be less.
I still don't see what this has to do with the rest of the thread.
Why did I say the winching distance must be short? Oh yes, I thought the gravity field is quite inform but the gravitating energy increases rapidly, so the force increases.
I forgot that "unifom" gravity field is not uniform.
So when everyting is taken into account the force is quite constant, over quite large distance, like there was some kind of force field that is quite uniform. Right?
Earlier in this thread me and PAllen were arguing about this matter.
  • #107
The term "uniform gravity field" is somewhat problematic, as you have seen. Strictly speaking, the term does not apply in the presence of an actual gravitating body; it applies to the apparent "gravity field" seen by a family of accelerated observers in flat spacetime that all maintain a constant proper distance from each other. The term "Rindler observers" is often used to describe such a family of observers. However, as you note, the acceleration felt by such a family of observers is actually not uniform; the observers "lower down" feel more acceleration than the ones "higher up".
In the presence of an actual gravitating body, tidal gravity is present, which makes the field of an actual gravitating body vary with distance in a different way than the apparent "field" seen by Rindler observers in flat spacetime. (Also, the variation with distance depends on the mass of the body, whereas there is only one possible variation with distance for the acceleration felt by Rindler observers in flat spacetime.) I believe the term "uniform field" was used to describe the flat spacetime case to emphasize the fact that there is no tidal gravity in flat spacetime; but it can be confusing to realize that even in the absence of tidal gravity, the "gravity field" seen by Rindler observers still varies with position.
Since you have set your scenario in the presence of an actual gravitating body, the criterion for being able to treat the force felt by an object as constant is that tidal gravity is negligible over whatever distance you are considering. The larger the mass of the body, the larger the distance over which the force can be treated as uniform.
