- #71
Buckleymanor
- 644
- 27
Simon Bridge said:In the archemedes diver, the air stopper (dropper?) changes density because surrounding water from the bottle is pushed into (or out of) it through the hole in the bottom.
Are you supposing that, following your analogy, air from outside the container is forced into (or out of) the container? You realize that the container is supposed to be airtight right?
Finally, the overall density of the dropper + contents, in the diver, changes.
In Gh778's experiment, the overall density of the container + contents does not change.
If there was no hole but greater pressure applied to the bottle the same effect would happen.
No air enters or escapes from the container yes it should be airtight.
Yes the overall density of the dropper +contents,in the diver, changes.
In Gh778's experiment, the overall density of the container +contents does not change.
Well it should not but the container is not made from an inelastic substance so if you introduce a tablet that has a chemical reaction and bubbles are produced because it is airtight? what happens to the container.
If it expands the overall density changes and the weight goes down.
If it leaks the weight goes down.
If it explodes the weight goes down.
If the scales are faulty then non of the above matter
