Why would we weigh less at earth's center?
  • Thread starter JeweliaHeart
  • Tags
    Center
In summary, according to Newton's universal law of gravitation, as you get closer to the center of the Earth, the mass of the object becomes smaller and smaller, ultimately making the quotient approach infinity. On the other hand, the explanation that all the mass around you cancels out at the center of the Earth seems to make sense, but both explanations contradict each other.
JeweliaHeart
68
I don't understand why we would weigh less at Earth's center(as opposed to sea level). Looking around the net, I have seen different approaches to this problem, each with different solutions.
According to Newton's universal law of gravitation:
F= Gm1m2/r2
If this is the case, then as r approaches nearly zero as the object gets closer to the center of the earth, the denominator gets smaller and smaller, making the quotient approach infinity.
On the other hand, I've heard the explanation that all the mass around you cancels each other out at the center of the earth.
This explanation also seems to make sense, but both explanations contradict each other..
Could someone please point out where I rationalized improperly
The law of gravitation only applies when you can consider the two objects as "point sources". For most situations, this approximation works well and will give good results. However, it does not work well when you burrow beneath the surface of the Earth, as you are now surrounded by matter on all sides and cannot use the formula anymore. At the center of the Earth the gravity from all the matter around you cancels out and you end up with zero net pull, meaning you don't weigh anything.
Okay. I am still slightly confused. What are "point sources", and how come the law of universal gravitation doesn't apply here?
A point source when you approximate an object's mass as being concentrated at a single point instead of being spread out. We can use the law of gravitation to find the force between the Earth and Moon if we consider both objects to have all of their mass concentrated at a single point at the center of each object. Then the r2 in the equation becomes the distance between these points. If you don't approximate the Earth and the Moon as point sources, you cannot use the equation because you no longer have a single mass and radius.
A "point source" is exactly what the phrase sounds like ... a source that can be TREATED as though it were a point. So when calculating the gravitational force between the Earth and the moon, both are treated as point sources.
You find the center of mass of a body and consider it as a point source at that point but with the mass of the whole thing. It is a convenient mathematical fiction.
When you are IMMERSED in a source, you can't treat it as a point source because it is all around you.
F= Gm1m2/r2
They don't contradict each other, actually. Your formula only works when you are outside a body (and when it can be treated as the equivalent of a single mass, all concentrated in one point. So, if the Earth were a totally uniform sphere, then the formula would be totally accurate because you can treat it as a single mass right at the centre. You actually need to be at some distance from the Earth for that assumption to work because the various parts have different densities and it's not symmetrical, either.
As you go beneath the surface, each spherical 'shell' that lies outside the level you're on has no net effect because the attractions of all the individual parts of the shell cancel each other out and it's only the stuff 'beneath your feet' that gives you a weight force. When you get to the centre, there is nothing beneath your feet ( the effective mass becomes nothing) so you will 'weigh' nothing. Of course, as you leave the centre, there will be a small restoring force, pulling you 'downwards.
Thanks for clearing this up everyone.
Let's say m1 is the mass of the Earth and m2 is your mass.
Per the shell theorem, any mass above your current depth cancels out. So, as R goes to 0 m1 also goes to 0 so at R=0 you have 0/0. In order to figure out exactly what that means you have to express m1 in terms of R and then take the limit as R goes to 0.
As it turns out in this case F goes to zero, but this is a prime example of a problem that is easy to solve with limits. If you are unfamiliar with them you should make a point not to remain so.
Related to Why would we weigh less at earth's center?
1. How is weight affected at the earth's center?
At the earth's center, the force of gravity is pulling in all directions equally, resulting in a net force of zero. This means that our weight, which is the measurement of the force of gravity on our body, would be zero at the earth's center.
2. Would we feel weightless at the earth's center?
Yes, we would feel weightless at the earth's center because our weight is determined by the force of gravity, and at the center of the earth, the force of gravity is essentially non-existent.
3. How does the earth's shape affect our weight at the center?
The earth's shape does not have a significant effect on our weight at the center. The force of gravity is still pulling in all directions equally, regardless of the shape of the earth.
4. Is there a difference in weight at the earth's center compared to the surface?
Yes, there is a significant difference in weight at the earth's center compared to the surface. This is because the force of gravity is stronger at the surface due to the mass of the earth being concentrated closer to the surface.
5. How does the earth's density affect our weight at the center?
The earth's density does not have a direct effect on our weight at the center. However, the earth's density does play a role in determining the force of gravity, which ultimately affects our weight at the earth's center.
  • Other Physics Topics
  • Earth Sciences
