I Will cooling or heating a pair of binoculars change the transmitted image?
  • I
  • Thread starter Thread starter ndvcxk123
    Cooling Heating
ndvcxk123
TL;DR Summary
The permittivity (epsilon) of glass+ water cause the angle change of a beam entering. How much is this change in angle under extreme temperature change, is it visible to the naked eye ?
Thanks!
Science news on Phys.org
You mean, does the refractive index of materials change with temperature?
It will probably change the focus - happens with telescopes.
ε depends on the electron density, which depends on the lens density, which depends on the differential thermal expansion of the lens and the tube it is in.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
