I Will insulation on electric power lines affect the flow of power?
  • I
  • Thread starter Thread starter KurtLudwig
Insulating electric power lines can significantly reduce sparking and fire risks during severe weather, but it also presents challenges. Insulated wires are more expensive, heavier, and require sturdier support structures, which can increase overall costs. While insulation does not impede the flow of electrical energy, it may lead to complications like increased melting points and potential fire hazards if insulation is damaged. The discussion highlights that underground power lines could be a more effective solution to reduce fire risks and maintenance issues. Ultimately, while insulation has benefits, the practicality and cost-effectiveness of underground installation may offer a better alternative for safety and reliability.
KurtLudwig
TL;DR Summary
Will insulation of electric power lines interfere with delivery of electric power? It would greatly decrease the setting of fires in dry conditions.
If electric power lines were insulated, there will be no or much less sparking between wires when poles are blown down during high winds.
(I am thinking of the recent fire in Lahaina, Maui. My granddaughter barely escaped the fire. The family lost all their homes.)
I had believed that electricity was conducted inside of copper wires. Then I read that the energy is carried by the electromagnetic field, mainly outside of the copper wires. How does insulation affect the electric field around a current-carrying wire? Will it impede the flow of electric energy?
I have also read on Wikipedia about a Poynting vector inside a co-axial cable. I am not sure I fully understand the concept of vectors. Could you elaborate?
  • Care
Likes berkeman and Dale
KurtLudwig said:
TL;DR Summary: Will insulation of electric power lines interfere with delivery of electric power? It would greatly decrease the setting of fires in dry conditions.
I am glad they escaped with their lives and sad to hear they lost their home.
Insulation would not impede the flow of electrical energy along the wires. It would add to the cost, both of the wire itself and also the supports needed to hold the extra weight.
Likes Klystron, KurtLudwig, vanhees71 and 2 others
Insulation is a disadvantage.
1. Insulated wire costs more than bare wire.
2. It weighs more, so needs thicker wire, and poles to support it.
3. It has greater wind section, so needs better support wires and poles.
4. The melting point of insulation limits the wire temperature, so wire must be thicker, which then needs a greater circumference of insulation.
5. In winter, it insulates, so prevents melting ice on the lines with reactive current.
A fallen insulated line will have a bare end without insulation. That will start surface fires.
Insulation is really only needed where trees can contact the power lines. Trimming trees will reduce the fire problem significantly.
If you insulate the wire, you might as well place it underground in a conduit.
Likes Klystron, vanhees71, DaveE and 1 other person
Thank you for your answers.
Likes russ_watters and berkeman
Undergrounding power is economic in new high-density suburbs, where the earthworks are planned with drainage, before the construction of roads.
Above-ground power, indirectly, reduces the height of trees in avenues. Trees block the sun and wind, which reduces temperature extremes. Tall trees cast longer shadows, over more PV panels. Tall trees drop limbs, or fall on houses during windstorms, or burn during bushfires.
My state-owned power-company inspector told me to replace my two privately-owned timber power poles, because they had signs of rot. They quoted AU$2k each at the time.
I have a vintage JCB backhoe for gardening, so I buried a 3PH line in conduit, from the road to my house. I now buy power at the front boundary. The power company had to finance and install a pole to cross the public road for my connection. At the same time, I converted from 1PH to 3PH, so they were required to upgrade their transformer, at their cost. I had to apply to Municipal Council for an easement, to cross the 1 foot (300 mm), underground from the State's pole to my boundary.
By going underground, I saved AU$1k and got 3PH power, (which would have required taller and more expensive power poles). I also escaped from the liability of rotting poles and overhead wires on my property.
Above all, I saved them the cost of doing the regular safety inspection of two private power poles.
Likes sophiecentaur, hutchphd, Klystron and 3 others
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
