Undergrad Will stars on the other side of the galaxy affect gravity here?
Gravity does not get "blocked" by intervening mass; rather, its influence decreases with distance. A star on the other side of the galaxy has a negligible effect on our Sun, primarily due to the gravitational influence of Sagittarius A. General relativity describes gravity as a geometric property of spacetime, where the curvature is related to the energy and momentum of matter. While distant stars contribute to the overall gravitational field, their individual effects are minimal compared to closer masses. The combined mass of all matter nearer to the center of the galaxy significantly impacts the Sun's orbit more than any single distant star.
KurtLudwig
TL;DR
Will the gravity of stars on the other side of Sagittarius not be blocked?
Does intervening mass between two stars decrease the gravitational attraction between these two stars?
Is gravity a local phenomenon in that local mass interacts with the surrounding gravitational field caused by the local star and distant stars?
Astronomy news on Phys.org
What have you read about the extent of gravitational effect for a given object? What does General Relativity say that gravity IS ?
I know I'm making it easy, but the simple answer here is "no", gravity doesn't get "blocked", it just decreases with distance. And yes, the galaxy's overall gravitational field is the sum of its parts.
Likes Vanadium 50
Nothing wrong with that.
If I say that a star on the other side of the galaxy has an almost negligible effect on our Sun. The main gravitational effect is due to Sagittarius. Is this statement correct?
Answering what General Relativity is: General relativity posits that gravity is a geometric property of four-dimensional spacetime. The curvature of spacetime is directly related to the energy and momentum of whatever matter and radiation are present. The relation is specified by a system of partial differential equations. (Which I read about, but which are way above my level.)
Thanks for your clarification.
Yes, but not because anything is "in the way" of its effect, just because it's so far away.
Exactly, which is why one thing doesn't have any effect on the gravitational impact of another thing, although their effects would be additive and a closer one will have a bigger effect (give similarities in mass).
Looked at another (simplistic) way, you can block EM radiation, but you can't block geometry and gravitational waves are geometry.
Likes Klystron and russ_watters
It is correct, in that you say main effect - but notice that it is not exclusive of that distant star. That star still has an influence.
In the grand scheme of things - 'the other side of our galaxy' is pretty much next door, compared to say, the stars of the Andromeda galaxy. They too have an effect on our galaxy (and thereby on our Sun), even though they're 25 times farther away.
And then recall that even whole galaxy clusters affect each other with their gravity. It's all just stars affecting other stars.
Likes 256bits
There are a hundred billion stars in the Milky Way, plus their satellites, black holes, dark matter, stray gases, etc. So sure, the fraction of that total mass carried by any one star is "negligible". It's possible to calculate exactly how negligible by picking a hypothetical star or a given mass and distance from Earth.
Likes DaveC426913
IOW, negligible - times 100 billion (or even just 10 billion) - is no longer negligible.
It would be an interesting exercise for the OP to work out what the gravitational acceleration would be of some fraction of stars at some set distance from Sol.
For example:
1010 stars at a distance of 105 light years
has the same attraction as
104 stars at a distance of 102 light years.
or
1 star at a distance of 1 light year.
(That can't be right. That means 10% of the galaxy on the far side of the galaxy has more effect (4x more) on Sol than Alpha Centauri!)
Code:
Rationale:
Num.(Sol=1)    Dist (ly)
10^10           10^5
10^8            10^4
10^6            10^3
10^4            10^2
10^2            10^1
10^0            10^0
Likes russ_watters
While Sagittarius A has a larger effect than that one star, the combined mass of all the matter closer to the center of the Galaxy than the Sun has an effect on the Sun's orbit many magnitudes greater than Sagittarius A alone does.
Likes alantheastronomer
  • · Replies 53 ·
  • · Replies 0 ·
  • · Replies 49 ·
