Wire Loop falling through uniform magnetic field
The discussion revolves around calculating the terminal velocity of a square aluminum loop falling through a uniform magnetic field. The magnetic field induces an electromotive force (EMF) in the loop, which generates a current that creates an upward magnetic force opposing gravity. The key equations involve the relationship between EMF, current, and resistance, as well as the magnetic force acting on the loop. The original poster initially struggled with eliminating the dimensions of the loop from the equations but later found that the length and resistance could be expressed in terms of the material properties of aluminum. Ultimately, the problem was resolved with assistance, highlighting the importance of understanding the physical properties involved.
Piamedes
A square loop is cut out of a thick sheet of aluminum. It is then placed so that the top portion is in a uniform magnetic field B, and allowed to fall under gravity. (B is perpendicular to the loop) If the magnetic field is 1 T, find the terminal velocity of the loop. Find the velocity as a function of time. How long does it take to reach 90% of the terminal velocity? What would happen if you cut a tiny slit in the loop, breaking the circuit? [Note: The dimensions of the loop cancel out; determine the actual number.]
My Note: It's from Griffiths
\epsilon = - \frac{d\phi_{B}}{dt} = - \frac{d}{dt} \int_S B \cdot da
F_{mag} = \int I \times B dl = I \int dl \times B
\epsilon = IR
I think I'm missing another equation or two, but I don't know which ones.
I first set one side of the square as length l.
The resistance of the wire is R.
B is parallel to the unit vector normal to the area of the loop, so:
\epsilon = - \frac{d}{dt} \int_S B \cdot da = -B \frac{da}{dt} = -Bl \frac{dy}{dt} = -Blv
\epsilon = IR
So:
I = \frac{\epsilon}{R} = \frac{-Blv}{R}
Now for the force. The cross product will cancel out on the two legs of the square, so only the component from the top of the square will contribute. Since I is clockwise as the square falls, the direction of the resulting force will be upwards.
F_{mag} =I \int dl \times B = I \int Bdl = BIl
Plugging in for I:
F_{mag} = (Bl)(\frac{-Blv}{R}) = \frac{-B^2 l^2 v}{R}
And this is where I get stuck. I can't seem to eliminate the length of the wire, nor its resistance from the equation. I assume there's some equation relating the natural resistivity of aluminum to its length, but I have no idea what it is or how to go about solving for this force without the dimensions of the wire. Any advice would be great.
Never mind, I worked it out with some help. the l squared over resistance quantity reduces to a ratio of the resistivity and density of aluminum
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
