Wolfram gave me one answer, examiners gave me another
  • Thread starter Thread starter Saibot
Saibot
Find the integral of 1/(2x-2)
u substitution
I removed the coefficient of 1/2 before integrating. So I had:
1/2 integral[(1/x-1)]
= 1/2 ln(x-1) + C
Using u substitution without removing the coefficient yields
1/2 ln(2x-2) + C
I get how it works both ways, and my answer must be wrong, but what exactly is causing this conflict? Am I not supposed to remove the factor of 1/2?
What is happening here?
##\ln(2x-2) = \ln(2(x-1)) = \ln(x-1) + \ln 2##
Therefore, ##\ln(x-1)## and ##\ln(2x-2)## differ only by a constant so both (divided by 2) are primitive functions of ##1/(2x-2)##.
What is happening is that as @Orodruin explained both are antiderivatives (=indefinite integrals) of the given function, however you use in both expressions the same letter ##C## for the constant and that is what is causing the confusion. We know that ##C## can be anything so it doesn't matter if you have just ##\ln x+C## in one expression and ##\ln x+C+\ln2## in the other, because if ##C## is anything, then so is ##C+\ln2## anything.
Got it, thanks guys. So I'm not actually wrong, we'll both just get different expressions for C.
Likes DaveE and Delta2
It's happens quite often with integration. For example:
$$\cos(2x) = \cos^2 x - \sin^2 x = 2\cos^2 x -1 = 1 - 2\sin^2 x$$Any one of these may result depending on how you tackle the integral $$-2 \int \sin(2x)\ dx$$
Likes SammyS and Saibot
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
