Wording of a Force and Motion problem
  • Thread starter Thread starter Beamsbox
    Force Motion
The discussion centers on the wording of a force and motion problem involving a firefighter sliding down a pole. The original poster struggles with the distinction between the forces described in parts a) and b) versus c) and d), believing they ask for the same information. They conclude that parts a) and b) refer to the pole's upward force on the firefighter, while c) and d) relate to the downward force the firefighter exerts on the pole. The consensus is that the book's wording is misleading, and it should clarify the relationship between these forces according to Newton's third law. Overall, the problem's phrasing creates confusion regarding the forces involved in the scenario.
Beamsbox
These are my forte... questions that make you feel dumb when you spend 20 minutes just thinking about what the hell they're asking... and then make you feel dumber once you figure out the simplicity of the answer...
Here we go, this has to do with the wording of the problem. To me a) and b), ask the same thing as c) and d)... but apparently I'm wrong.
Firefighter (712N) sliding down a pole...
a) asks for the magnitude and b) asks for the direction "of the vertical force on the firefighter from the pole."
c) asks for the magnitude and d) asks for the direction "of the vertical force of the pole on the firefighter."
I have figured out a) and b), b) being upwards. [a) is 494N which I'll reference later.]
The book says that c) has the same magnitude as a), but that d) is in the opposite direction (down).
Now I have looked at the problem like this:
a) and b) are asking about the force that the pole is exerting on the firefighter, and since it is slowing him down, it would be in the upwards direction.
Say that c) and d) are asking for the force that the firefighter exerts on the pole (I assume this because the answer says that the direction is down), this makes sense because the force the firefighter exerts on the pole would equal the force the pole exerts on the firefighter, and as a system, the remaining force is what propels the downward motion (that left over from the restriction of the upward force against the gravity).
Am I wrong to way that the book has worded this question correctly, and that the quoted and underlined sentences above are asking for the same information?
Thanks all!
The wording is clearly wrong.
I'm sure the question meant to ask you about the Newton's 3rd Law pair of forces.
One is the vertical force of the pole on the firefighter, and the other is the vertical force of the firefighter on the pole.
Thank you, I thought I was crazy on this one.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
