Wordle Lovers - Play the NYT Daily Game
  • Thread starter fresh_42
  • Tags
    Game
In summary, the player played the New York Times daily word game and found that they had a higher fail rate in playing against Spanish-speaking humans. They also mentioned that the game is similar to a board game they remember from their childhood.
  • #5,916
Wordle 1,268 3/6
  • #5,917
Orodruin said:
No.
Cute!
Likes gmax137
  • #5,918
Wordle 1 269 3/6
β¬›πŸŸ©β¬›β¬›β¬›
β¬›β¬›β¬›β¬›πŸŸ¨
  • #5,919
Wordle 1,269 6/6
⬛⬛⬛⬛⬛ [ARISE] 78 left
πŸŸ¨β¬›πŸŸ©β¬›β¬› [LOUSY] filter - 6 left: BLUNT CLUMP CLUNG FLUNG PLUMB PLUMP
β¬›πŸŸ©πŸŸ©β¬›β¬› [PLUMP] filter/most-probable - 3 left: BLUNT CLUNG FLUNG
β¬›πŸŸ©πŸŸ©πŸŸ©β¬› [BLUNT] most-probable - 2 left
β¬›πŸŸ©πŸŸ©πŸŸ©πŸŸ© [CLUNG] :mad:
🟩🟩🟩🟩🟩 [FLUNG]
This one went from bad to worse. I was tossing and turning so much for my 3rd guess because there was no obvious choice. I should have gone for PLUMB and lost myself with PLUMP. Then I really like BLUNT for the 4th guess (which I would have known to be wrong had I used PLUMB before) and went for it even if it wasn't the best choice for eliminating possibilities. Then I was stuck with the two equally less appealing words out of the initial six after my 2nd guess; of course, I had to pick the wrong one.
The worst thing is that even if I followed the "correct" way, I would still have had it in 5 guesses: ARISE LOUSY PLUMB CLUNG FLUNG.
Two fails for the most-probable method in one game. o:)
most-probable method count update (Success/Fail): 38/21 - 64.4%/35.6%
Likes dwarde
  • #5,920
Wordle 1,269 3/6
  • #5,921
Wordle 1,269 5/6
⬜🟩🟩🟩🟩 picked the wrong one!
  • #5,922
Wordle 1,269 3/6
β¬›β¬›β¬›πŸŸ©β¬›
πŸŸ¨πŸŸ¨β¬›πŸŸ¨β¬›
  • #5,923
Wordle 1,269 5/6
  • #5,924
jack action said:
Wordle 1,269 6/6
Did you tweak your software recently? Your first filter has the same wrong letter in the same wrong place as your seed. Perhaps a typo on your part? I use a spreadsheet, so typo's are not beyond my capabilities.
My algorithm picked POUTY as your second guess, leaving CLUNG, CHUCK, and FLUNG, a clear win in either 3 or 4, vs 6.
Likes Orodruin
  • #5,925
My algorithm finds the most popular letters in the possible answers. In this case, with no letters found with ARISE, it found OUYLM as the most popular letters in the remaining words and tried to find a matching filter with those letters. There wasn't one so it removed the least popular letter M and tried again with the remaining four and it found LOUSY.
  • Wow
Likes dwarde
  • #5,926
Wordle 1 270 3/6
πŸŸ¨β¬›β¬›β¬›πŸŸ¨
β¬›β¬›πŸŸ¨πŸŸ¨β¬›
Dropping the most uncommon letter is likely suboptimal if you are adding a letter that is already excluded. LOUSY is also a lot of vowels that can many times be inferred.
I don’t see why you don’t apply the same algorithm as for your starting word to subsequent guesses when you want a filter. Running it on a smaller subset of words should be significantly faster.
  • #5,927
Because I did not have an algorithm for my starting word initially. The whole thing was something I'd thrown quickly for fun.
All good advice I've received here - and noted - but understand that this is the first time that the program has let me down like that.
  • #5,928
One could say it gave you a LOUSY suggestion. 😬
Likes jack action
  • #5,929
Wordle 1,270 6/6
  • #5,930
Wordle 1,270 3/6
β¬›πŸŸ¨πŸŸ¨β¬›πŸŸ¨ [ROAST] 4 left: OCTAL PATIO QUOTA TANGO
β¬›πŸŸ¨β¬›β¬›β¬› [LINES] filter - 1 left
🟩🟩🟩🟩🟩 [PATIO]
One of the other problems with my program: the suggestions for the second guess filter were EQUIP PIQUE QUIPO QUIPS QUIPU QUOPS.
Here is what it does:
  1. It correctly identifies the remaining letters as CL PI QU NG;
  2. It creates an array with key=letter and value=occurence count. The natural order of the array in bash is apparently reverse alphabetical of the keys;
  3. The array is sorted by value, in this case, all 1s so no change: U Q P N L I G C;
  4. It keeps the first 5 items of the array (UQPNL) and tries to find a word with these letters;
  5. If not found, it drops one letter until it finds one. In this case, it stops at UQP and finds the 6 guesses previously shown.
What I did to find my filter, was:
  1. to recognize that I needed three of the following: one C or L, one P or I, one Q or U, or one N or G;
  2. that it would be helpful to use a vowel, i.e. one I or U.
And thus LIN was quickly recognized by my brain as the start of many words I could use.
It is this process that is harder to translate into a [simple] algorithm.
Likes dwarde and OmCheeto
  • #5,931
jack action said:
Wordle 1,270 3/6
🟩🟩🟩🟩🟩 [PATIO]
PATIO was a perfectly good filter. Always check if one of the words in the possible solutions would filter the others.
(PATIO has the same O position as TANGO and the same T position as OCTAL, no positions common with QUOTA)
Likes OmCheeto
  • #5,932
See, I didn't even note that. o:)
That should be another step to add to the algorithm which makes it even more complex. It's really amazing how the brain works.
Likes OmCheeto
  • #5,933
Wordle 1,270 3/6
  • #5,934
Wordle 1,270 3/6
  • #5,935
Wordle 1,270 3/6
β¬›πŸŸ¨πŸŸ¨πŸŸ¨β¬›
πŸŸ©πŸŸ¨β¬›πŸŸ¨πŸŸ¨
  • #5,936
Wordle 1,270 4/6
  • #5,937
Wordle 1,271 3/6
πŸŸ©β¬›πŸŸ©β¬›β¬› [POUTY] filter - 2 left: PLUMB PLUMP (dΓ©jΓ  vu)
🟩🟩🟩🟩🟩 [PLUMB]
Without looking at my previous result, my gut told me to do the opposite of what I did before, and here we are.
most-probable method count update (Success/Fail): 39/21 - 65.0%/35.0%
  • #5,938
Wordle 1,271 3/6
  • #5,939
Wordle 1,271 4/6
πŸŸ¨β¬›πŸŸ©πŸŸ¨β¬›
πŸŸ©πŸŸ©πŸŸ©πŸŸ©β¬›
  • #5,940
Wordle 1,271 6/6
🟩🟩🟩⬜⬜ I see two choices
🟩🟩🟩🟩⬜ wrong one!
Likes dwarde
  • #5,941
Wordle 1,271 5/6
  • #5,942
Wordle 1 272 3/6
β¬›β¬›πŸŸ©β¬›πŸŸ¨
  • #5,943
Wordle 1,272 3/6
  • #5,944
Wordle 1,272 4/6
β¬›β¬›πŸŸ©β¬›β¬› [ARISE] 26 left
β¬›β¬›πŸŸ©πŸŸ©β¬› [CLINT] filter - 3 left: DYING OWING VYING
β¬›πŸŸ©πŸŸ©πŸŸ©πŸŸ© [DYING] filter - most-probable - 1 left
🟩🟩🟩🟩🟩 [VYING]
most-probable method count update (Success/Fail): 39/22 - 63.9%/36.1%
  • #5,945
Wordle 1,272 6/6
jeez...
That's a good filter, eliminating the "L" culls out a lot of words
