Work and heat transfer in internal combustion engine
The discussion focuses on calculating the power absorbed during the compression stroke of a two-cylinder internal combustion engine, given specific parameters and a compression law of PV^1.2 = const. A participant is struggling to match their calculated power output with the provided answer of 17.95 kW, suspecting a potential error in the compression law, possibly suggesting it should be PV^1.4 instead. Another contributor clarifies that the correct approach involves understanding the volume swept by the piston, indicating a misunderstanding in the initial calculations. The conversation highlights the importance of accurate application of formulas and understanding the physical principles involved in engine compression. The correct solution emphasizes the need to properly calculate the volume swept by the piston to achieve the expected results.
Suman_babai
★★ members are requested to crop images so that only that content essential to the thread is posted ★★ ❌
: [/B]At the beginning of the compression stroke of a two-cylinder internal combustion engine the air is at a pressure of 101.325 kPa. Compression redeuces the volume to 1/5 of its original volume, and the law of compression is given by PV^1.2 = const. If the bore and stroke of each cylinder is 0.15 m and 0.25 m , respectively, determine the power absorbed in kW by compression strokes when the engine speed is such that each cylinder undergoes 500 compression strokes per minute.
The answer is given as : 17.95 kW
2. Homework Equations :
I hv written all formulas in the solution (attachment).
:[/B] I hv attached the solution I hv done. Please rectify my mistake... where I am doing wrong..my ans is not matching with the given one.
Are yo usure this is not pV^1.4 ?
that could be a printing mstake... thanks... this book is just full of calculation errors.
And if you calculate it with 1.4? do you get the right answer? (it is 1.4 because for adiabatic expressions pV^(1+2/f)=const. and f=5 for air. )
no.. it is coming around 16.(something)... may be the question is wrong.. thanks anyway.
2. Homework Equations : I hv written all formulas in the solution (attachment).
Here is correct solution bro. V1-V2= Volume swept by piston.
Volume swept by piston not equal to v1, where you went wrong.
Likes Chestermiller
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
