Work and Kinetic Energy of cord
A block of mass M is lowered at a constant acceleration of g/4, prompting a discussion on the work done by the cord and gravitational forces. The work done by the cord is calculated as 3Mgd/4, while the work done by gravity is Mgd, not Mgd/4, as the gravitational force acts to increase the block's energy. The kinetic energy and speed of the block can be derived from these work values without needing specific numerical inputs. The analysis emphasizes that the work done by the cord opposes gravity, affecting the block's motion. Understanding these relationships is crucial for solving the problem accurately.
saber1357
A cord is used to vertically lower an initially stationary block of mass M at a constant downward acceleration of g/4. When the block has fallen a distance d, find (a)the work done by the cord’s force on the block, (b) the work done by the gravitational force on the block, (c) the kinetic energy of the block, and (d) the speed of the block. [Maintain Significant Figures]
F=m*a
W=F*d
I have no idea how to even begin this problem. First of all, I cannot even begin to comprehend how to obtain an answer consisting of actual numbers from a mass "M" and a distance "d". The only physical number I have is g/4 which is 2.45m/s^2. If someone can help me with this problem, it will be greatly appreciated.
In the absence of the cord, the block will experience a force = Mg. With cord the force is Mg/4. Hence the cord is exerting a retarding force
= 3Mg/4. With this retarding force the block has fallen a distance d. Therefore the work done by the cord on the block is = 3Mgd/4, and work done by the gravity = Mgd/4. From this you can find out KE and speed.
To solve the problems there is no need of numerical values.
So my answer will be in the form of "M" and "d"?
Yes, it's in the form of M and d. Apologies to rl.bhat, but can you explain why the work done by gravity is NOT Mgd/4? Notice the work done by the cord is taken out of the block and the work done by gravity goes into the block.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
