Work (Conservation of Energy/Newton's Laws)
  • Thread starter Thread starter jzwiep
    Laws Work
Sam, a 75kg skier, descends a 50m high, 20-degree frictionless slope while facing a 200N headwind. Using work and energy principles, he calculates his speed at the bottom to be approximately 15.73 m/s, while applying Newton's laws yields a lower speed of about 12.23 m/s. The discrepancy arises from an error in calculating the force component of the headwind; it should be 200*cos(20) instead of 200/cos(20). This miscalculation affects the net force and acceleration used in the Newton's laws approach. Correcting this will align both methods and provide a consistent answer.
jzwiep
MP 11.44
Sam, whose mass is 75kg, straps on his skis and starts down a 50-m-high, 20degree frictionless slope. A strong headwind exerts a horizontal force of 200N on him as he skies. Find Sam's speed at the bottom (a) using work and evergy (b) Using Newton's laws
v2=v02 + 2ad
Dot product
(a)
U = K + WHeadwind
vf=sqrt(2*(mgh+F*(h/sin20)*cos(160))/m)
Which got me= 15.7270m/s
(b)
Fnet = Fg - Fheadwind
a=(mgsin(20)-200/cos(20))/m
v2=v02 + 2ad
v= sqrt(2ad)
Which got me: 12.225m/s
I'm not sure where I went wrong. Any thoughts?
What's the component of the 200N force parallel to the slope?
200/cos(20) means that component of force along the slope is greater than the force itself!
You should write 200*cos20. Well, maybe it is just a typing error (like evergy) because you wrote mg*sin20 and not mg/sin20
Thanks. I drew the triangle backwards.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
