Work done by conservative force
The discussion revolves around the work done by conservative forces and how to apply the relevant equations in physics problems. It clarifies that the total work done by all conservative forces in a system can be expressed as the sum of the work done by each individual conservative force, equating to the change in potential energy and kinetic energy. Participants emphasize the importance of understanding the net force acting on an object and how it relates to changes in kinetic energy, rather than strictly categorizing forces as conservative or non-conservative. The conversation also highlights the need for proper textbooks that include derivations and applications of these principles for better comprehension. Overall, the key takeaway is that while terminology may vary, the fundamental relationships between work, energy, and forces remain consistent in physics.
gracy
I know work done by conservative forces= - ##ΔU##=##ΔK.E##
But I have a question.Does it mean work done by all the conservative forces present (in a particular physics problem)= - ##ΔU##=##ΔK.E##
or just work done by a conservative force= - ##ΔU##=##ΔK.E##
I mean let's say a problem in physics involves both electrostatic and gravitational force We know both are conservative forces.Should I equate work done by gravitational force +work done done by electrostatic force=-##ΔU##=##ΔK.E##
or should I treat each force separately.If yes,then I don't now how am I going to treat each force separately.
It should be the total.
Likes gracy
You should consult your textbook and see how this equation is derived. That should provide answers to your questions.
You mean this one is correct
My textbook does not involve the derivation, it just includes application .
I confirm it is the total. Think of it this way: the object experiences a net force ##F_{net}##. We know that determines its motion: ##F_{net}=ma##. The acceleration, over a period, determines its change in KE.
By the way, we are here discussing the conservative forces acting on the body which gains this KE. We are not interested in forces acting on other bodies in the same system.
Likes gracy
And similarly in case of non conservative force
Work done by non conservative force=##ΔK.E##+##ΔP.E##
Does it mean Work done by all the non conservative forces present in a (particular physics problem)=##ΔK.E##+##ΔP.E##
I doubt that, or you have an incredibly bad textbook.
The work-energy theorem comes from integrating Newton's second law:
$$\int_{\vec{r}_i}^{\vec{r}_f} \left(\sum_i \vec{F}_i\right)\cdot d\vec{r} = \int_{\vec{r}_i}^{\vec{r}_f} m\vec{a}\cdot d\vec{r}.$$ The righthand side is equal to the change in kinetic energy. On the lefthand side, we can pull the summation out of the integral to get
$$\sum_i \int_{\vec{r}_i}^{\vec{r}_f} \vec{F}_i \cdot d\vec{r} = \frac 12 mv_f^2 - \frac 12 mv_i^2 .$$ Each integral in the summation is just the work done by force ##i##, so we have
$$W_1 + W_2 + W_3 + \cdots + W_n = \frac 12 mv_f^2 - \frac 12 mv_i^2$$ where ##W_i = \int \vec{F}_i\cdot d\vec{r}##. If a force is conservative, we bring its contribution to the work over to the other side of the equation and rename it as the change in potential energy. That is, ##\Delta U_i = -W_i##. The stuff left on the lefthand side is the work done by non-conservative forces. So now we have
$$W_{nc} = \Delta KE + \Delta U_1 + \Delta U_2 + \cdots + \Delta U_k.$$ If there are no non-conservative forces, the lefthand side is 0, and you end up with
$$0 = \Delta KE + \Delta U_1 + \Delta U_2 + \cdots + \Delta U_k.$$
Likes gracy
gracy said:
work done by gravitational force +work done done by electrostatic force=-ΔU=ΔK.E
I think you misunderstand the significance of "conservative" here. The work done on an object by any force is ΔKE. What's special about conservative forces is that the work done is independent of the path taken. If the object returns to its original position, the total work done by the force is zero.
Work done by non conservative force=ΔK.E+ΔP.E
No. PE is not a property of the individual body. It is a property of a system. For gravitational PE 'of' an object in Earth's field, the PE is possessed by the object-Earth system. A force may do work which raises that PE, but is not considered work done on the body.
A force, conservative or not, may do work on the body (ΔKE) and work on the system (ΔPE).
Likes gracy
Here also I categorized conservative forces ,If it is correct
why not this
work done by Sum of all the non conservative forces=ΔK.E+ΔP.E
why not this
Why do you keep referring to conservative and non conservative forces in this thread? I have mentioned several times that these work equivalence equations have nothing to do with whether the forces are conservative. I have provided you with the condition that determines whether a force is conservative or not.
I agree with Haruspex. The source of your confusion lies in the practice of referring to forces as conservative and non-conservative. Whoever taught it to you this way has done you a disservice. How about revealing the name of the book you are using so others can be warned against using it.
Chet
Likes gracy
gracy said:
So how should I solve such questions?
Even in this thread https://www.physicsforums.com/threads/definition-of-potential-energy.834808/page-4
I considered conservative and non conservative ,it was not a problem then.I am lost.
For whatever it's worth, I think you are obsessing over this terminology too much. Your time is much too valuable for that. If you want to specify a specific problem, we can talk about how to solve it.
Chet
Likes gracy
But It s much convenient for me to use those terminologies (conservative /non conservative)I loved the answer Mister T gave me in https://www.physicsforums.com/threads/definition-of-potential-energy.834808/page-4 post #61/I was having only one doubt which I posted here in this thread but now all are telling me to stop using those terminologies .I desperately want to stick to those terms and formulas (conservative/non conservative)Can not I?Is there no way?
You should do whatever works best for you. It's a personal thing.
Chet
Likes gracy
You mean it is not wrong to use conservative/non conservative forces for work calculations?
Like I said, whatever works best for you.
Likes gracy
Then I will choose conservative/non conservative force approach for work done calculation,but as I said to apply those formulas I need to clear a doubt
please help me to get the answer of my op and post#7.:smile:
I can't help you because the terminology drives be crazy. All you need to remember is that the change in KE is equal to the work done by the net force.
Chestermiller said:
I can't help you
I really needed the answer.
This is all I'm going to say:
The work done by both conservative and non-conservative forces (as you call them) is always equal to the integral of the force specific dotted with the displacement.
For a conservative force, the work can also be expressed in terms of a change in potential, without carrying out the integration.
In post #7, the change in kinetic energy plus potential energy is equal to the work done by the non-conservative force. But you typically can't use this equation to get the force done by the non-conservative force by summing the change in potential energy plus kinetic energy because you typically don't know what these are in advance. To get the force done by the non-conservative force, you still typically need to need to integrate the force with respect to displacement. Only in homework problems where you are told the change in kinetic energy plus potential energy can you back out the work of the non-conservative force. But to do this, you have to be told in advance what the change in kinetic energy is.
Likes gracy
Why did not you include change in potential energy?I should know (should be given in the question)change in potential energy as well as change in kinetic energy in order to calculate work of the non-conservative forces using formula
##W_nc##=##ΔK.E##+##ΔP.E##
Right?
Having read that post, I think I finally understand where the confusion lies. i misunderstood the relationship between the PE term there and the forces under consideration.
In your equation ##W_{nc}=\Delta PE+\Delta KE##, the ##\Delta PE## refers to the sum of all potentials present, so covers all the conservative forces. The work done by those is ##-\Delta PE##. If there are no other forces present then this equals ##\Delta KE##, the work done on the body. The sum of all non-conservative forces present accounts for any discrepancy between ##\Delta PE +\Delta KE## and 0.
That said, the separation of forces into those roles can be hazy. A real spring is mostly conservative, but not entirely. You would need to split the spring force into a conservative component and a non-conservative one.
Yes.
Right?
Yes, but I hope you understand that, when the equation is written and applied in this way, it is typically only being used "diagnostically," to deduce what the non-conservative work must have been to produce the observed change in kinetic energy and potential energy. Ordinarily, you would calculate the non-conservative work directly from the corresponding force and displacement, and then use that to calculate what the change in KE + PE is. So, for this kind of application, you would interchange the right- and left hand sides of the equation.
Chet
Likes gracy
How Shall I proceed with this?To calculate the non conservative work
##W_nc##=##∫\vec{F}_nc##.##\vec{d}##
Right?
Right?
It depends on the specific problem. For example, if it's kinetic friction, then F = μN.
Chet
Likes gracy
You must get a better textbook. Did you open a thread in the learning materials forum as I suggested last time?
You are wasting everyone's time by using bad learning material.
11K
  • · Replies 33 ·
