High School Work Done By Conservative Forces
  • Thread starter Thread starter Heisenberg7
    Forces Work
Work done by conservative forces is defined as the negative change in potential energy, expressed mathematically as W_c = -ΔU. This relationship connects to the work-energy theorem, which states that the change in kinetic energy (ΔK) is equal to the work done on an object. In scenarios where only conservative forces, like gravity, are acting, the work done translates directly into changes in kinetic energy. For example, when a mass falls, the work done by gravity increases its kinetic energy while decreasing its potential energy, illustrating the connection between these concepts. Understanding this relationship helps clarify how energy is conserved in mechanical systems.
Heisenberg7
I did classical mechanics a while ago and I was going over some stuff that I wasn't sure if I understood correctly and now I've come over this one. It says that work done by conservative forces is equal to the negative difference in potential energy. Or, ##W_c = - \Delta U##. And I've really been trying to make sense of this. I know that when energy is conserved we have ##\Delta E = 0 \implies \Delta K + \Delta U = 0 \implies \Delta K = - \Delta U##. Does that have something to do with this equation? Would that also mean that work done by conservative forces is equal to the change in kinetic energy? What I am thinking: It kind of does make sense. Let's say we have a conservative force. Then work done by it is ##W_c = \int_{a}^{b} \vec{F} \cdot \vec{dl}##. If ##W_c > 0## then it helps object's motion so work done by it would actually increase object's velocity. So if there are no other forces, all the work done would go into change of kinetic energy. But how does that relate to the change in potential energy? I would just like to hear a kind of intuitive argument to why this connects to the previous equation (##\Delta K = - \Delta U##) if I'm right. Not just mathematically, but an example.
Thanks in advance.
One of the ways a conservative force ##\mathbf F## is defined is that it can be derived by a scalar potential energy ##U##. In three dimensions, one would write $$\mathbf F=-\mathbf{\nabla}U.$$ So it's a matter of definition. Note that you can the potential energy if you know the force using a line integral, $$U(\mathbf r)=-\int_{\mathbf{r}_{\text{ref}}}^{\mathbf r}\mathbf F\cdot d\mathbf r$$where ##{\mathbf{r}_{\text{ref}}}## is the point where the potential energy is assumed to be zero.
Consider this example. A mass fall from rest and hits the floor at distance ##h## below. Find the landing speed of the mass.
You can use the work-energy theorem and say that the change in kinetic energy of the mass is equal to the net work done on it. Here gravity is the only force that does work. So you write $$\begin{align}
& \Delta K=W_{\text{grav}} \nonumber \\
& \left(\frac{1}{2}mv^2-0\right)=mgh.
\end{align}$$If you want to use energy considerations, you would write
$$\begin{align}
& \Delta K+\Delta U=0 \nonumber \\
& \left(\frac{1}{2}mv^2-0\right)+\left(0-mgh\right) =0.
\end{align}$$ Equations (1) and (2) are algebraically identical. However, the work done by gravity on the right side of equation (1) becomes the negative of the change in potential energy on the left side of equation (2).
Likes Heisenberg7
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 77 ·
  • · Replies 54 ·
  • · Replies 48 ·
