- #36
- 27,395
- 18,863
jbriggs444 said:Do the math.
Do the exercise!
Do the math. The work being done by the legs is indeed zero and not mgv. See if you can find out why.PeroK said:Do the exercise!
jbriggs444 said:Again, this is completely irrelevant. The work performed by your muscles is the work performed by your muscles.
Do the math. Here. I'll do it for you. There are two interfaces. Hips and feet. You are standing on a treadmill in motion.PeroK said:Your muscles do little or no work to stand up. Your body can produce a force of ##mg## downwards without any effort. It's the force over and above ##mg## that is provided by your muscles.
On a treadmill (or step machine), the additional force is to keep lifting your legs.
On a real hill the additional force is to lift your whole body.
If you go to the gym and experiment, you will see this immediately. The difference is fundamental.
I'll add a +1, but elaborate:jbriggs444 said:Completely irrelevant. The work done by feet on belt is the same regardless of what other forces act on the belt.
Let me try a different way: since the treadmill moves itself, you have to apply a force to it to keep from falling off the back of it. That force is larger the higher the slope. And that force, times the speed of treadmill, is the power you apply, and it is exactly the same as climbing a hill.PeroK said:The treadmill moves itself. There is no need to do any work to move the treadmill. To make it go faster, you press a button!
russ_watters said:Let me try a different way: since the treadmill moves itself, you have to apply a force to it to keep from falling off the back of it. That force is larger the higher the slope. And that force, times the speed of treadmill, is the power you apply, and it is exactly the same as climbing a hill.
The muscles go through the same motion either way. The notion that the force is "provided by gravity" is not well posed and is irrelevant.PeroK said:Yes, but most of that force is provided by gravity, not by your muscles. That's the difference.
A force is needed to resist gravity. If you prefer we can treat gravity as a fictitious force and adopt a free fall inertial frame, but that seems pointless.Anyway, a force is only needed to accelerate; not to stay stationary.
Yes. Walking or running on a flat treadmill is equivalent to walking or running on a springy sidewalk. However, walking up an incline requires force to maintain one's state of motion in spite of gravity.Imagine a flat treadmill. The same applies. You need to walk to stop going off the end of it, but once you have attained the required speed, you only need the biomechanical energy to keep walking.
Yes, friction provides a force. But only as long as it is resisted.On an inclined but stationary treadmill, friction keeps you from sliding down.
Yes indeed. You need to power your legs in order to maintain the strain that allows the friction to exist. That's power required on the downstroke.On an inclined treadmill, you need to walk. Friction still holds your weight in place, but your legs are pulled down and you need extra enrgy to keep lifting them up.
Unfortunately, the proffered explanation for this "evidence" is just plain wrong.The evidence, however, is clear: you can do speeds and "height" gains on a treadmill that are impossible on a real hill.
jbriggs444 said:Unfortunately, the proffered explanation for this "evidence" is just plain wrong.
I made no judgement about the evidence. It is the explanation that is incorrect.PeroK said:It may turn out that my evidence is "plain wrong"
This notion that a force of one object on another being "provided" by some other source is decidedly unphysical.PeroK said:The work done/power by the person's muscles is ##fv##. Where ##v## is the speed of the treadmill. There is no need for the muscles to assume the additional burden of providing the force ##F## when the treadmill is moving. ##F## continues to be provided by gravity.
Ok...so that's the work, right?PeroK said:On an inclined moving treadmill, you need a combination of these: You need to walk. Friction still holds your weight in place, but your legs are pulled down and you need extra energy to keep lifting them up.
A.T. said:When the treadmill runs at constant speed, the only difference is air resistance. Just analyse the treadmill from the inertial frame, where the upper belt surface is at rest. Here you continuously move upwards, just as you would on a real hill.
russ_watters said:Ok...so that's the work, right?
The person standing next to the treadmill is irrelevant, because it is not interacting with you.PeroK said:Yes, but so does everything else. The person standing next to the treadmill is also continuously moving upwards in this frame.
Do you know of any objective proof for this massive difference? Like measurements of used oxygen, etc?PeroK said:And yet, there is a massive difference between the two
A.T. said:Do you know of any objective proof for this massive difference? Like measurements of used oxygen, etc?
Aside from air drag, you have different visual queues on a treadmill. This could explain some difference, but hardly a massive one.
Yes, if the slope of the real hill varies a lot, that could explain why it's more exhausting.PeroK said:Perhaps, alternatively, these machines simply allow you to spread the load and the overall work is the same, but it's easier to sustain because it's all evened out.
Again, this is incorrect. The effort to pull the legs upward is not the only work being done by the hip and knee extensors.PeroK said:Yes, the work is only the work needed to keep moving the legs up and down. It's not the work needed to move your whole body mass continuously against gravity.
I think the simplest way to avoid such confusions is to look at both scenarios from the rest frame of the support surface. Here the work done on the surface is zero, so all the gain in potential energy comes from muscles.jbriggs444 said:Again, this is incorrect. The effort to pull the legs upward is not the only work being done by the hip and knee extensors.
Agreed. Like doing deep knee bends in an elevator. It does not matter whether the elevator is moving upward or downward in the shaft or even whether it is stopped. As long as it moves at a steady velocity, its motion is irrelevant to the work done by the muscles.A.T. said:I think the simplest way to avoid such confusions is to look at both scenarios from the rest frame of the support surface. Here the work done on the surface is zero, so all the gain in potential energy comes from muscles.
Mechanically, there is nothing different about the legs compared to a static incline.PeroK said:As you push with your foot, your foot is being drawn back towards your body. This allows you to push largely from directly below you. On a real hill, a lot of the work is done by the foot in front of you.
Sorry, but you are glossing over the issue being discussed. When not moving up or down against a gravitational field, you can say no work is done against gravity, but that doesn't mean no work is being done against anything. A common similar example is a helicopter doing work against the air when hovering. Again, the power is force times [air] velocity.FactChecker said:My two cents:
Stopping something from falling (either free fall or any other downward trajectory) can not be considered work. It would not be possible to say that a person on an inclined treadmill is doing work while at the same time saying that a table that keeps a book from falling is not doing work. The standard definition of work (force times distance) can not be changed without opening a can of worms.
But you can say that the man on the treadmill is expending energy and the table holding up a book is not. That can be done easily without any tricky definitions or controversy.
Or the other way around: Imagine you walk up a hill, enclosed in an opaque box that that has a hole in the floor (of same size as the treadmill), The box drives up the incline at constant speed, and you have to keep up, while walking on the ground within the floor hole.Grinkle said:@PeroK Let the treadmill become longer, say 100m long or 1000m long or whatever length is helpful to make it seem the same as no treadmill mentally - and install a fog machine at the end so you lose sight of the end. Install whatever other visual queues you might think of to remove any visual evidence that you are not running on the ground.
Not true. Gravity is the only force being opposed. This is not similar to a hovering helicopter because the helicopter is pushing the air around and a person on an inclined treadmill is not pushing the treadmill down. The treadmill surface is rotating down on its own and would do that if no one was on it. I have not "glossed over" the problem. I have thought about this several times over decades and could not come up with a consistent definition of "work" other than the standard one.russ_watters said:Sorry, but you are glossing over the issue being discussed. When not moving up or down against a gravitational field, you can say no work is done against gravity, but that doesn't mean no work is being done. A common similar example is a helicopter doing work against the air when hovering. Again, the power is force times [air] velocity.
I disagree with the claim that no work is officially being done. The official definition of work involved the force that is applied and the motion of the target object at the point where the force is applied. There is an alternate definition of "center-of-mass" work which involves the motion of the center of mass of the target object.FactChecker said:But you can still talk about expending energy while no "work" is officially being done.
Are we really going to have to engage in this whole debate again? Do you really want to claim that a person on a treadmill is not exerting a downward force on a moving treadmill belt?FactChecker said:Not true. Gravity is the only force being opposed. This is not similar to a hovering helicopter because the helicopter is pushing the air around and a person on an inclined treadmill is not pushing the treadmill down. The treadmill surface is rotating down on its own. I have not "glossed over" the problem. I have thought about this several times over decades and could not come up with a consistent definition of "work" other than the standard one.
Irrelevant.FactChecker said:A person on a treadmill is not changing the motion of the treadmill. The treadmill surface would be moving the same way if no one was on it.
