Work done when Inserting a Dielectric between Capacitor Plates
Inserting a dielectric between capacitor plates involves two scenarios: one with a disconnected battery, where the charge remains constant, and another with a connected battery, where voltage is constant. In the disconnected case, the work done by the electric force is negative due to the reduction in potential energy as the dielectric is inserted, while in the connected case, the work is positive because the battery adds energy to maintain voltage. The professor explained that the electric field's fringe effects create a downward force during dielectric insertion, influencing the work done. The mathematical relationships clarify that in the connected case, the battery compensates for the energy change, leading to an increase in potential energy. Understanding these concepts can be aided by visualizing the electric field dynamics rather than solely relying on equations.
lorx99
Hi,
today in lecture, we discussed the work done on inserting a dielectric between a capacitor.
Two cases of this example:
One case, where the battery is disconnected so that the charge stays constant.
Other case where the battery stays connected so voltage is constant.
I am confused on why the work by the electric force for the disconnected battery is negative, while the work for the connected battery is positive. The professor discussed something about the fringed electric field that results in a force downwards by the electric field when we insert the dielectric. Also, he mentioned how when work is positive, energy is added, so it makes sense that the final energy state for inserting dielectric into a connected battery-capacitor increases. Vice versa to the disconnected battery..
I am confused on what is happening specifically for each case and more important "why".
Can someone please explain this concept?
The disconnected case is simple because there is only kind of electrical force that does work on the system and that is due to the electric field generated by the isolated charge on the plates. In that case the work done by the electrical forces is ##dW=(-dU)## and the force would be ##F = -\left( \frac{\partial U}{\partial x} \right)_Q## where ##x## is the direction of insertion and the derivative is explicitly taken at constant ##Q##.
The connected case is a bit more complicated because the work done by the battery needs to be taken into account. The work done on the system is ##dW=dW_{batt.}+(-dU)##. At constant voltage, when charge ##dQ## is added to the positive plate, ##dU=(1/2) V dQ##. Also, the work done by the battery to raise the potential energy of ##dQ## from zero to ##V## is ##dW_{batt}=VdQ##. Clearly then, ##dW_{batt}=2dU##. Thus the work done on the system at constant voltage is ##dW=2dU+(-dU)=+dU## and the associated force is ##F = +\left( \frac{\partial U}{\partial x} \right)_V##
Is there a more conceptual way to explain this like with the fringes? I just don't do well with equations/proofs that explain concepts :/.
You asked for an explanation
Math is the language of physics and does a wonderful job when one wants to explain what specifically is going on with a system. If that's too much for you, you can wave your hands and say something like "In the disconnected case the system is isolated and the insertion of the battery results in a reduction of the potential energy and a drop in the voltage across the capacitor. In the connected case, the battery pumps additional charge on the plates up to voltage V thereby increasing the potential energy of the system."
Likes lorx99
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
