MHB Work energy principle and power
The discussion revolves around calculating the speed of a box sliding down a ramp using the work-energy principle. The height of the ramp is 20 cm, and the box starts from rest, allowing for the application of conservation of energy. The gravitational potential energy (GPE) at the top is converted into kinetic energy (KE) at the bottom, leading to the equation 1/2mv^2 = mgh. By substituting the values for g and h, the mass cancels out, simplifying the calculation. The final speed of the box at the bottom of the ramp is determined to be 2 m/s.
Shah 72
MHB
A box slides down a smooth ramp. The height of the ramp is 20cm and the length of the ramp is 2.5m. The box starts from rest. What is the speed of the box when it reaches the bottom of the ramp?
I don't understand how to solve this. Pls help
Mathematics news on Phys.org
We can apply conservation of energy.
What is the energy due to gravity at the beginning?
What is the kinetic energy at the end?
Increase in KE= loss of GPE
1/2mv^2= mgh
So gpe at the top = m×10× 0.2
GPE at the bottom = 0J
You have the correct equation.
Fill in g and h.
And we can cancel m from both sides.
Fill in g and h.
h=0.2m, so v= 2m/s. I was getting confused with the length of the ramp.
Thanks a lottt!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
