MHB Work energy principle and power
To find the average power generated by a car of mass 1200 kg accelerating up a 10-degree incline, the calculations involve determining the acceleration, force exerted by the engine, and the work done. The initial speed is 10 m/s, and the final speed is 12 m/s after 60 seconds, leading to an average velocity of 11 m/s. The average power can be calculated using the work-energy principle, which includes changes in kinetic and gravitational potential energy. The textbook answer is 36,000 W, while some users reported different values, indicating a need for careful calculation and consideration of all forces involved.
Shah 72
MHB
A car of mass 1200 kg accelerates up a hill inclined at 10 degree to the horizontal. The car has initial speed of 10 m/ s and final speed of 12 m/s after 60 s. Air resistance and friction may be ignored. Find the average power generated by the engine.
The and in the textbook is 36000 W, iam not able to do. Pls help
Mathematics news on Phys.org
Again what have you been able to do? You've posted a large number of these questions and have learned nothing about how to start? How about a diagram and a statement of the work energy theorem? See what you can do, then if you still are getting an incorrect answer post what you have done and we can look it over.
-Dan
-Dan
Iam getting the ans 31180W, but textbook ans is 3600W
I first calculated acceleration using v= u+at and got a= 0.033m/s^2
Then calculated F- 16000sin10=1600×0.033 and got the ans F=2831.7N
Then calculated s using v^2= u^2+2as and got s= 660.67m
Avg power= work done/ time
Iam not getting the right ans. Pls help
Well, I'm not getting either of those values. First off, some basic values ...
$a = \dfrac{\Delta v}{\Delta t} = \dfrac{1}{30} \, m/s^2$
$v_{avg} = \dfrac{v_0+v_f}{2} = 11 \, m/s$
$\Delta x = v_{avg} \cdot \Delta t = 660 \, m$method 1
$P_{avg} = \dfrac{\text{total work done by the engine}}{\text{elapsed time}}$
$P = \dfrac{\Delta KE + \Delta GPE}{\Delta t}$
$\color{red} P = \dfrac{\frac{1}{2}m(v_f^2-v_0^2) + mg \Delta x \cdot \sin{\theta}}{\Delta t}$
method 2
$P_{avg} = (\text{force exerted by the engine})(\text{avg velocity}) = F_e \cdot v_{avg}$
$F_e - mg\sin{\theta} = ma \implies F_e = m(g\sin{\theta} + a)$
$\color{red} P = m(g\sin{\theta}+a) \cdot v_{avg}$
method 2
Thank you!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
