Work energy theorem problem -- Block sliding up a curved incline
In summary, the work-energy theorem problem involving a block sliding up a curved incline analyzes the relationship between the work done on the block and its change in kinetic and potential energy. As the block moves along the curved surface, gravitational forces and friction play a crucial role in determining its motion. The theorem states that the total work done on the block equals the change in its mechanical energy, allowing for the calculation of the block's speed and height as it ascends the incline. Key considerations include the initial velocity, the angle of the incline, and the shape of the curve, which all influence the energy transformations occurring during the block's motion.
tellmesomething
410
45
A 10kg small block is pulled in the vertical plane along a frictionless surface in the form of an arc of a circle of radius 10m. The applied force is 200N as shown in the figure. If block is started from rest at A then speed at B would be? (g=10m/s^2)
None
I did: Work done by gravity+work done by applied force= KE(final)- KE(initial)
Work done by gravity should simply be -mgh
=100*5=-500J
For work done by applied force we know:
W=∫F⋅ds
which can also be written as
W=∫Fdscos(θ)
since F is constant i can take that out
W=Fcos(θ)∫ds
here since ive resolved the dot product isnt ds the length of the arc?
Following that i get
arc length= \frac{\pi}{3} \times 10
= (3.14*10)/3
Now im stuck here as im not sure what the angle is? Is it the angle between displacement and the force or distance travelled(arc) and the force?
Any help would be appreciated
Imagine you are the one doing the work by pulling the string horizontally with the force ##\vec F##. When your hand undergoes a small displacement ##\vec{ds}##, what is the direction of ##\vec{ds}##? What is the value of the angle ##\theta## between your force ##\vec F## and the displacement of the force ##\vec ds##?
is it 30 deg?
tellmesomething said:
is it 30 deg?
I don't believe so. I interpret the figure as showing a string attached to the block with the string passing over a little pulley. The pulley is fixed in place and the force F is applied at a point on the horizontal part of the string, such as the red dot shown:
The displacement of the red dot corresponds to the displacement of the force. When the string is pulled a little bit, in what direction does the red dot move? How does this direction compare to the direction of the force?
but i thought it would just be tangential to the arc? isnt that the dirn of displacement in circular motion
The infinitesimal displacements of the block are tangent to the arc. But that doesn't enter into calculating the work done on the system by the applied force F.
Think of the system as consisting of the block and the string. Three external forces act on this system: the force of gravity, the normal force acting on the block from the frictionless surface, and the horizontal force applied to the string. According to the work-energy theorem, the change in KE of the system equals the net work done by these three forces. You've already got the work done by the force of gravity. You still need the work done by F and the work done by the normal force.
Oh so its just 0?
Oh so its just 0?
Yes.
PeroK said:
Yes.
should i have calculated the work done by the net force on the block i.e tension minus the component of mg ? instead of just tension or does the work done by gravity already accounts for it?
In general, you calculate the work done by each force separately. You should know that by now.
Look at the original diagram and imagine you are applying for ##F## over a certain distance. The work done by that force is independent of what the force is doing inside the box.
Also, the string outside the box and the force ##F## could be at any angle to the fixed pulley and the work done is the same.
Likes tellmesomething
i see ok thankyou.......
FAQ: Work energy theorem problem -- Block sliding up a curved incline
What is the work-energy theorem?
The work-energy theorem states that the work done on an object is equal to the change in its kinetic energy. Mathematically, it is expressed as W = ΔKE, where W is the work done, and ΔKE is the change in kinetic energy.
How do you apply the work-energy theorem to a block sliding up a curved incline?
To apply the work-energy theorem to a block sliding up a curved incline, you need to calculate the work done by all forces acting on the block (such as gravity, friction, and normal force) and set it equal to the change in the block's kinetic energy. This involves integrating the forces along the path of the incline.
What forces need to be considered in this problem?
The primary forces to consider are gravitational force, the normal force from the incline, and any frictional forces present. Gravitational force does work on the block as it moves up the incline, while the normal force typically does no work because it acts perpendicular to the direction of motion. Friction, if present, will do negative work, opposing the motion.
How do you calculate the work done by gravity on the block?
The work done by gravity can be calculated using the formula W = mgh, where m is the mass of the block, g is the acceleration due to gravity, and h is the vertical height gained by the block. For a curved incline, h is the difference in height between the starting and ending points of the block's path.
What role does the shape of the incline play in solving the problem?
The shape of the incline affects the path length and the distribution of forces along the path. For a curved incline, the path length is longer than for a straight incline, and the normal force may vary along the path. This means that the integration of forces to find the work done may be more complex, requiring knowledge of the specific curve equation.
