Work & Horsepower: Pulling a 65 kg Skier Up a 30° Slope
  • Thread starter Thread starter netprincess
    Horsepower Work
To calculate the work required to pull a 65 kg skier up a 30° slope for 50 m at a constant speed of 2.9 m/s, one must first determine the force needed to counteract gravity on the slope. The vertical component of the skier's weight can be calculated to find the necessary pulling force. The work done is then found using the formula W = Fd, where F is the force and d is the distance. Additionally, to find the horsepower required, the work done over time must be converted to power, noting that 1 horsepower equals 746 watts. The discussion emphasizes understanding the relationship between force, work, and power in this frictionless scenario.
netprincess
A skier of mass 65 kg is pulled up a slope by a motor-driven cable, a)How much work is required to pull him 50 m up a 30° slope (assumed frictionless) at a constant speed of 2.9 m/s? b)how much horsepower must the motor have to preform this task?
Please help! I don't know what to do with this... I know it's a simple question but I've managed to get all confused. Where do I start? :rolleyes: Thank you!
Find the force pulling the skier down the hill. This is the force required to pull him up. That is a good place to start. From there, remember that KE=(1/2)mv^2 and also that W=Fd.
a) How long does it take to cover 50 m if the speed is 2.9 m/sec? How much vertical distance does it rise in that time? How much energy did it use in that time? What is the rate of work done/unit time?
b) How many Joules/sec is 1 horsepower?
AM
There is no change in kinetic energy in the problem as stated, so the power is not used to provide kinetic energy.
AM
AM
If it has velocity and mass, doesn't it have kinetic energy?
The skier does have kinetic energy when he's being pulled. I think what Andrew meant was that there was no change in this KE, as the question didn't mention about the skier starting from rest, but being pulled with constant velocity instead.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
