Work in mechanics and thermodynamics
The concept of work in thermodynamics differs significantly from mechanics, where work is defined as the integral of force and displacement. In thermodynamics, a person climbing stairs may not be considered to do work because the energy transfer is primarily in the form of heat rather than mechanical work. The equation for work in thermodynamics, dW = PdV, highlights that pressure can represent energy per volume, complicating the understanding of work further. Additionally, the distinction between work done on a system and work done by a system is often blurred, particularly under the assumption of reversible processes, which do not exist in reality. Finally, discrepancies in sign conventions between mechanics and thermodynamics can lead to confusion in calculations.
mikyway
Hi, I'm new to this forum . I have long been puzzled over the concept of work in thermodynamics. In mechanics work is defined as the integral of of the force and the displacement dot product. So if they are perpendicular , the work is by definition zero.But in thermodynamics it appears fuzzy. To take an example from thermodynamics , a man who climbs a flight of stairs is said to do no work even though from a mechanics point of view the work will be nonzero . I apologize for being wordy as I ' m unfamiliar with Latex
Science news on Phys.org
We define pressure most commonly by force per area BUT it is also energy per volume. This gives the most common form of work in thermodyamics
dW = PdV
Say you want to push down on an air tight cylinder containing a compressible fluid. This takes energy to accomplish. Some of the energy goes into work that actually compresses the fluid and some goes into heat.
The above equation is not as simple as it appears, however. The P term is determined by the equation of state (ideal, van der Waals, Redlich Kwong, Peng Robinson...) which are commonly approximately by virial equations and can be many characters long.
It's not common or sometimes accurate to express thermodynamic variables as vectors. It doesn't really give any extra information, so it's left in simple scaler form.
Who says this? The man has increased his potential energy by moving upwards against the force of gravity. That's work in my book.
Date of OP ?
mikyway said:
.// I have long been puzzled over the concept of work in thermodynamics. In mechanics work is defined as the integral of of the force and the displacement dot product. // But in thermodynamics it appears fuzzy.
Although it is somewhat shocking, I think it must be admitted that 'work' in thermodynamics is fuzzy.
For the man who climbs the stairs, the only energy transfer from the body(system) to the environment is heat (no sweat): no work is done. Chemical energy stored in glucose is (partly) transformed to the potential energy of the same body. There is transformation of one form of energy to another, but the energy stays in the body.
Secondly in case of a system with piston (eg steam engine) no distinction is made between the work done on the inside of the piston and work done on the outside of the piston, due to a strong belief in reversible processes, which assume p(in)=p(out), hence W(in)=w(out). However in the real world there is no such thing as a reversible process.
( This problem is properly dealt with in the attachement in https://www.physicsforums.com/showthread.php?t=338573 )
Third, there is a sign problem (as indicated by mrmiller1 who leaves th minus-sign out of the equation for work). The sign convention of mechanics is sometimes at odds with the sign convention of thermodynamics.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
