Work is done against friction, producing thermal energy
The statement "Work is done against friction, producing thermal energy" is generally correct, as friction does work and results in thermal energy generation. Friction converts kinetic energy into thermal energy, illustrating the energy transformation that occurs during frictional interactions. The accuracy of the statement can depend on specific situations, but the fundamental principle remains consistent. Understanding this relationship is crucial in physics and engineering contexts. Overall, friction plays a significant role in energy conversion processes.
nokia8650
216
Is this statement correct:
"Work is done against friction, producing thermal energy"?
Thanks
To be as precise as possible - it depends on the situation.
In general however, "friction does work - producing thermal energy." And if you want to be really hardcore, friction converts kinetic energy to thermal energy.
Thank you, I appreciate it.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
