Work out the amount that Arjun paid in rent in 2019
  • Thread starter Thread starter chwala
    equations Linear
The discussion focuses on calculating the amount Arjun paid in rent in 2019 using linear equations and ratios. Participants propose different methods, with one approach establishing equations based on the ratios of Arjun's and Gretal's payments in 2018 and 2019. The calculations lead to the conclusion that Arjun paid $6,525 for the year 2019. There is also a confirmation of the equations used, with participants agreeing on the results. Overall, the conversation emphasizes the effectiveness of using linear equations to solve the problem.
chwala
See attached.
Ratio
I am interested in a more direct linear equations approach...to solve, which i know is possible...
A. My initial thinking was along the lines,
let ##x## be the amount that Arjun paid in 2018 and let ##y## be the amount that Gretal paid in 2018 where A was the total amount paid in 2018 ... this gives me the equation,
In 2018,
Arjun paid: ##\dfrac{5}{12} A = x## and Gretal paid: ##\dfrac{7}{12} A = y##. Therefore, my first equation is,
##\dfrac{5}{12} A + \dfrac{7}{12} A= x +y##
I need time to finish up on this...
B. My alternative approach which was more direct is
In 2018,
Arjun : Gretal =##45 : 63##
in 2019,
Arjun : Gretal =##45 : 65##
Therefore,
##63 = x## and ##65 = 290 +x##
##63(290 +x) = 65x##
##18,270 +63 x = 65x##
##18270 = 2x##
##x= $9135##
Therefore in 2019, Arjun paid ##\dfrac{9135}{7}=$1305× 5 = $6525##.
There could be a better approach. Cheers.
This is the ms approach. Not quite clear to me.
You have four unknowns, one for each person for each year: ##A_8, A_9, G_8, G_9##.
You have four statements, which give you four equations:
##\frac {A_8} {G_8} = \frac 5 7##
##\frac {A_9} {G_9} = \frac 9 {13}##
##A_8=A_9##
##G_9-G_8=290##
Solve the equations.
Likes chwala and SammyS
##A_8=A_9##
##G_9-G_8=290##
Smart 🤓
Hope your equations are correct...will post my working later.
...I can confirm that equations are correct will post working later. Thanks man!
We have
##A_8 = \dfrac{5}{7} G_9 - \dfrac{1450}{7}##
and
##A_8 = \dfrac{9}{13} G_9##
##\left[\dfrac{9}{13} G_9 = \dfrac{5}{7} G_9 - \dfrac{1450}{7}\right]##
##G_9 = \left(\dfrac {1450}{7} × \dfrac {91}{2}\right) = \left(\dfrac{131,950}{14} \right)= 9,425##
##⇒A_8 =\dfrac{(9 × 9,425)}{13} = 6,525##.
I get the same ($6525). That's pretty pricey digs!
Edit, oops I was thinking it was 6525 per month. For the whole year that's not so bad, near $550/month.
Your results in Post# 4 look fine.
In this Post, I will show a somewhat more direct way to get to the quantity asked for in the OP, Arjun's rent in 2019. Like you, I will be using @Hill 's variable definitions and set of equations.
##\dfrac {A_8} {G_8} = \dfrac 5 7##
##\dfrac {A_9} {G_9} = \dfrac 9 {13}##
##A_8=A_9##
##G_9-G_8=290##
Since ##\displaystyle A_8=A_9\, ,## I will choose to use ##\displaystyle A_9## to refer to either.
Use the two ratio equations to express ##\displaystyle G_8 \text{ and } G_9## in terms of ##A_9##.
##\displaystyle \quad G_8=\dfrac 7 5 A_9 \text{ and } G_9=\dfrac {13} 9 A_9 \ ##.
Plugging those into the equation ##G_9-G_8=290## we get the following.
##\displaystyle \quad \dfrac {13} 9 A_9-\dfrac 7 5 A_9 ==290##
Multiply both sides of the equation by ##9\cdot 5## to eliminate fractions.
##\displaystyle \quad (5\cdot 13 - 9\cdot 7 ) A_9 = 9\cdot 5\cdot 290##
Aarrgh that's the ms method on my attached post ##1##. Cheers.
  • · Replies 46 ·
14K
  • · Replies 61 ·
11K
  • · Replies 114 ·
11K
  • · Replies 39 ·
13K
  • · Replies 101 ·
19K
  • · Replies 86 ·
14K
  • · Replies 98 ·
15K
  • · Replies 83 ·
21K
