Work to create a square of charges
To calculate the work required to create a square charge configuration with charges at infinity, the initial work for the first charge is zero. The work for the second charge is determined by the interaction with the first charge, calculated as k*q1*q2/r12. For the third charge, the work includes contributions from both the first and second charges, expressed as k*q1*q3/r13 + k*q2*q3/r23. The final charge's work can be similarly derived by considering its interactions with the other three charges. Understanding these interactions is crucial for solving the problem effectively.
supersunshine
hi,
i'm completely stuck on this problem
the problem asks for an expression for the work required to create a square charge configuration starting with the charges starting at infinity:
each side is length a. on the top left corner the charge is +q, top right: -q, bottom left: -q, bottom right +q
change in potential energy= work
U= kqq/r
Since the charges begin at infinity, the work will equal the final potential energy. I think potential energies can be added, but if you add all the charges at equal distances you will get zero. I also tried chosing a corner and adding the potential energies relative to the corners but did not get the right answer.
thank you for your help!
supersunshine said:
hi,
U= kqq/r
The work required to bring the first charge is zero.
The work required to bring the second charge will be \frac{k q_1 q_2}{r_{12}} where r_12 is the distance between those two charges at the final position. The work required to bring the third charge is \frac{k q_1 q_3}{r_{13}} +\frac{k q_2 q_3}{r_{23}} since q_2 and q_3 are already there. You can guess the formula for the work to bring the last charge :-p !
Hope this helps
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
