I Would moving the mouths of a wormhole affect the internal distance?
  • I
  • Thread starter Thread starter Earthworm69
    distance Wormhole
Earthworm69
TL;DR Summary
If you move one mouth of a wormhole away relative to the other mouth, what happens to the space inside of it?
Lets say I formed a traversible wormhole with one mouth on each end of my garage. If I picked up one of the ends and drove it to the park, would the distance inside the wormhole increase or otherwise be effected as well?
This is my first post on physics forums - Hi everybody!
https://en.wikipedia.org/wiki/Wormhole
In the traversable wormhole solution described in the Wikipedia article you reference, the one published by Kip Thorne and others, no, the distance through the wormhole would not change.
Welcome!
Are there any solutions where the inside distance can change if the mouths are moved?
Not that I'm aware of, but I am not up to date on all of the wormhole literature.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
