B Would the following test be proof of a successful propulsion system?
  • B
  • Thread starter Thread starter Fizzics
    Box Propulsion
The discussion centers on the feasibility of a propulsion system contained within a sealed box, fixed to a swing or pendulum, that could propel itself forward without external assistance. Participants argue that while the apparatus might demonstrate movement, it does not provide evidence of a viable propulsion system for space travel, as it relies on mechanisms not applicable in a vacuum. The energy required for propulsion raises questions about how it would enter the sealed environment. The topic is linked to reactionless drives, which are prohibited in the forum. Consequently, the thread was closed for moderation due to its controversial nature.
Fizzics
If an apparatus was placed in a sealed box, and was then fixed to the seat of a childrens swing or a pendulum.
And then, if it could propel itself (total mass 10kg) forward approximately 5 inches with a single pulse independently of any outside assistance and also without repositioning any masses within the box.
This pulse could then be repeated an unlimited amount of times, also there would be no external influences such as a fan or wind.
Would this apparatus then be proof of a successful propulsion system that could be used in outer space?
  • Skeptical
  • Haha
Likes davenn, Vanadium 50 and PeroK
No.
It might move a swing, but that says nothing about space travel, where there is no rope or tensile force. The swing, and the tree that supports it, rotates with the Earth on its axis.
How would the energy required for a propulsion system enter the sealed box?
Thread prefix changed from "A" (graduate school level) to "B" (basic).
Thread closed temporarily for Moderation...
This appears to be an attempt to discuss Reactionless Drives. They are a Forbidden Topic per the PF Rules. The thread will remain closed.
PF Forbidden Topics said:
EMDrive and other reactionless drives
See https://www.physicsforums.com/threads/nasas-em-drive.884753/
Likes davenn
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
9K
