Would we see the planets move across the sky if Earth stops spinning
In summary, if the Earth did not spin on its axis, we would only be able to see the stars during a half of the year. However, since the Earth is still moving, we would see stars/planets shifting across the sky but not to completion.
kirsten_2009
137
If the Earth did not spin on its axis, would the other planets still appear to move across the sky? Justify your answer.
N/A
If the Earth continued to rotate around the sun but NOT on it's own axis then wouldn't we see that there is roughly six months of light and six months of darkness and thus only be able to see the stars for half the year? That being said, since the Earth is still moving in respect to the sun, wouldn't we see the stars/planets (during the six months of darkness) shifting across the sky but not to completion and a lot slower (so not as fast as we do in a 24 hour period but still to some degree)?
If we assume that our orbit around the sun is a circle of fixed radius (1 AU), then the relative position of a planet would depend on 1) its distance from the sun and 2) the space (temporarily speaking) of our two measurements. Neptune, for instance, is around 30 AU away from our sun and completes an orbit in approx. 165 years. An easy math can help in figuring out the length of the arc that this planet would have moved in a period, say, of 6 months. The same applies for the rest of the bodies of our solar system, and thus closer planets will experiment wider displacements. Remember that this technique (Parallax) is used to measure distance for stars in our own galaxy.
Likes 1 person
Thanks so much for your reply. I understand what you are saying; but, conceptually speaking then would my answer be correct? or I guess, sufficiently correct?
If the Earth stops spinning then we would see a 'fixed' starry picture above our heads (at night, our long six-month night), for the stars are pinned far enough not to seem they're moving. Regarding to the planets, they would still be moving across the ecliptic line, because they keep orbiting on the plane of our galaxy. I suppose you're right when you say we would see them as we see now every night, but quite longer. That is, we could see Mercury completing several orbits during our night, but Jupiter (orbit approx. 12 y), for example, just moving some arc. Hope I made it a little bit clear :D
Yes, totally clear! thanks! :)
Good, have a good day! :)
You can sometimes see Venus in the daytime so I would ignore that issue.
kirsten_2009 said:
If the Earth continued to rotate around the sun but NOT on its own axis then wouldn't we see that there is roughly six months of light and six months of darkness and thus only be able to see the stars for half the year? That being said, since the Earth is still moving in respect to the sun, wouldn't we see the stars/planets (during the six months of darkness) shifting across the sky but not to completion and a lot slower (so not as fast as we do in a 24 hour period but still to some degree)?
I took me a while to figure out what you meant by "not to completion." I assume you mean the planets won't necessarily rise or set in this scenario.
There are three different types of motion involved in explaining what we observe in the night sky. There's the rotational motion of the Earth (about its axis), its orbital motion around the Sun, and (the one you seem to have neglected) the orbital motion of the other planets around the Sun.
As you correctly realized, the planets and stars will no longer rise and set because that apparent motion is due to the rotation of the Earth. What effect does the orbital motion of the other planets have on what we see? What effect does the Earth's orbital motion have on what we see? Will you still observe retrograde motion of Mars?
Related to Would we see the planets move across the sky if Earth stops spinning
1. How often would we see the planets move across the sky if Earth stops spinning?
The frequency of seeing the planets move across the sky would depend on the rotation of Earth. If Earth were to stop spinning, we would see the planets move across the sky once every 24 hours, which is the length of a day on Earth.
2. Would we still see the planets move across the sky if Earth stops spinning?
Yes, we would still be able to see the planets move across the sky if Earth stops spinning. This is because the planets themselves are in motion around the sun, so they would still appear to move across the sky even if Earth stops spinning.
3. How would the lack of Earth's spin affect the motion of the planets?
The lack of Earth's spin would not have a significant impact on the motion of the planets. The planets would still revolve around the sun, but they would no longer appear to move across the sky due to Earth's rotation.
4. Would the planets appear to move in the opposite direction if Earth stops spinning?
No, the planets would still appear to move in the same direction in the sky, which is from east to west. This is because the direction of their motion is determined by their orbit around the sun, not Earth's rotation.
5. Would there be any noticeable changes in the appearance of the planets if Earth stops spinning?
The appearance of the planets would not change significantly if Earth stops spinning. They would still appear as bright points of light in the night sky, and their positions in relation to each other would remain the same. However, without the rotation of Earth, there would be no day and night cycle, so the planets would be visible at all times.
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
