MHB Write a trigonometric expression as an algebraic expression
The discussion revolves around converting the trigonometric expression cos(arccos x + arcsin x) into an algebraic form. The key identity used is arccos(x) + arcsin(x) = π/2, which simplifies the expression. By applying the angle-sum identity for cosine, the expression can be rewritten as a product of cosine and sine functions. The final result of the expression is determined to be zero. The participants express clarity and understanding as the problem is worked through collaboratively.
Taryn1
This problem probably should be easy, but I don't remember learning the basic way to do these problems: Write the trigonometric expression as an algebraic expression:
The answer is zero, but I don't know how to get there...
Mathematics news on Phys.org
Recall the identity:
$$\arccos(x)+\arcsin(x)=\frac{\pi}{2}$$
However, I suspect you are to use the angle-sum identity for cosine to write:
$$\cos\left(\arccos(x)+\arcsin(x)\right)=\cos\left(\arccos(x)\right)\cos\left(\arcsin(x)\right)-\sin\left(\arccos(x)\right)\sin\left(\arcsin(x)\right)$$
Can you continue?
Ohhhh, I think I get it now. Thanks!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
