MHB X^6 - y^6 As Difference of Squares
The discussion focuses on factoring the expression x^6 - y^6 as a difference of squares. The initial factorization is presented as (x^3 - y^3)(x^3 + y^3), leading to the application of the difference of cubes for further simplification. The first factor can be factored using the difference of squares, while the second factor is addressed through a system of equations to find coefficients. Ultimately, the expression is fully factored as (x^2 - y^2)(x^4 + x^2y^2 + y^4) and further simplified to (x^2 + xy + y^2)(x^2 - xy + y^2). The discussion emphasizes the importance of recognizing both difference of squares and cubes in the factorization process.
mathdad
Factor x^6 - y^6 as a difference of squares.
Solution:
The problems states to use the difference of squares.
I can apply the difference of cubes to the left factor and the sum of cubes to the right factor but how do I continue using the difference of squares?
Mathematics news on Phys.org
Once you've done that' you've applied the difference of squares...to continue factoring further, as you noted, you need to use the sum/difference of cubes. Now, if you begin with the difference of cubes, you'd have:
$$x^6-y^6=(x^2-y^2)(x^4+x^2y^2+y^4)$$
Now to continue, you would use the difference of squares on the first factor. To factor the second factor, we can try:
$$x^4+x^2y^2+y^4=(x^2+axy+y^2)(x^2+bxy+y^2)=x^4+(a+b)x^3y+(ab+2)x^2y^2+(a+b)axy^3+y^4$$
Equating coefficients, we obtain the system:
$$a+b=0\implies a=-b$$
$$ab+2=1\implies ab=-1$$
And so we find:
$$(a,b)=(\pm1,\mp1)$$
And we may write:
$$x^4+x^2y^2+y^4=(x^2+xy+y^2)(x^2-xy+y^2)$$
This is what we would find by using the difference of squares first, and then applying the sum/difference of cubes, so that's the simpler route to take. :D
And so we find:
And we may write:
I can use u and v in terms of (x^4+x^2y^2+y^4) just like I did in the other post, right?
You'd wind up with radicals if you do that. :D
Good information.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 38 ·
  • · Replies 19 ·
  • · Replies 68 ·
12K
  • · Replies 21 ·
