Y-Delta conversion for Capacitors
  • Thread starter Thread starter cupid.callin
    Capacitors
The discussion centers on the Y-Delta conversion for capacitors, addressing confusion about applying resistor formulas to capacitors. Participants clarify that while the Y-Delta transformation is similar for both components, capacitors require conversion to their equivalent impedance using the formula Zc = 1/(jωC). The correct formulas for converting between Y and Delta configurations for capacitors are provided, emphasizing that the algebra remains straightforward despite the imaginary values involved. The conversation concludes with a confirmation that similar principles apply when converting Delta to Y, using the appropriate capacitor impedances. Understanding these conversions is crucial for analyzing circuits with capacitors effectively.
cupid.callin
This was a ques in my book ... (Pic)
After thinking a while, i realized that it can be solved using Y-Delta (by converting Y to delta form) conversion. But i couldn't get the answer ... i don't know why ...
I used this http://en.wikipedia.org/wiki/Y-%CE%94_transform"
It is given for resistors ... i guess its same for resistors and capacitors ... Right?
Please tell me if the eqn used is wrong or something else!
Remember how capacitors combined differently in series and parallel than do resistors?
What you can do is convert all your capacitances to their equivalent impedance, then use those formulae. Impedances mix and match like resistances.
How do i find impedance of a capacitor?
Zc = 1/(j\omega C)
\omega is the operating frequency. The result is in Ohms, and will be an imaginary value.
Don't panic! You don't need to know the frequency for the math to work out; it's a constant for the given Y to Delta situation. If you do the algebra, a pretty simple result obtains. If the resistor version is:
Ra = (R1*R2 + R2*R3 + R3*R1)/R2
Rb = (R1*R2 + R2*R3 + R3*R1)/R3
Rc = (R1*R2 + R2*R3 + R3*R1)/R1
Then the capacitor version looks like:
Ca = C1*C3/(C1 + C2 + C3)
Cb = C1*C2/(C1 + C2 + C3)
Cc = C2*C3/(C1 + C2 + C3)
And to find Y form,
C1 = (CaCb + CbCc + CcCa) / Cc
Right?
Thanks for the help gneill !
Thanks a lot !
cupid.callin said:
And to find Y form,
Right?
Thanks a lot !
Right.
You're welcome.
gneill said:
... for the given Y to Delta situation. If you do the algebra, a pretty simple result obtains. If the resistor version is:
The three capacitors enclosed in red form a Y. So does the other set of 1, 3, and 4 μF capacitors. Converting each of these sets to Δ configuration, as shown by gneill above, will allow you analyze the circuit as a combination of parallel and series capacitors.
Thanks for the help!
Is there a simple result for delta to Y as well?
Sure. Just substitute the appropriate capacitor impedances into the formulas for resistance, stir and serve. Note that a capacitor impedance is of the form 1/(j \omega C).
So for example, given that for resistors
R_1 = \frac{R_a R_b}{R_a + R_b + R_c}
then
\frac{1}{C_1} = \frac{C_c}{C_b C_c + C_a C_c + C_a C_b}
and so on.
EDIT: Fixed up the expression. Should have been 1/C1 on the LHS.
Thank you! :)
