Young's Modulus: Calculate from Length, Radius, Elongation & Weight
  • Thread starter Thread starter monkeymak7
    Modulus
To calculate Young's modulus for a wire, the formula E = (F/A₀)/(ΔL/L₀) is used, where F is the force applied, A₀ is the cross-sectional area, ΔL is the elongation, and L₀ is the original length. In this case, the force is calculated as F = mg, resulting in 117 N for a 12 kg weight. The cross-sectional area A₀ is determined using the radius, yielding approximately 2.8 x 10^-8 m². Substituting these values into the Young's modulus equation gives a result of 0.0165 GPa. This calculation illustrates the relationship between stress and strain in elastic materials.
monkeymak7
A wire, of length 250 centimeters, and radius 0.3 millimeters is stretched by hanging on a weight of 12 kilograms, and the elongation produced is 8 millimeters. Calculate the value of Young’s modulus for the wire.
I have no idea because we never went over this...please please guide me in the right direction
In atomic units, where the unit of length is 1 bohr radius (a_{0} \equiv \hbar^{2}/(m_{e} \, k_{0} \, e^{2}), the unit of mass is the electron mass m_{e} and the unit of energy is 1 hartree (E_{0} = m_{e} \, (k_{0} \, e^{2})^{2}/\hbar^{2}), the unit for Young's modulus (pressure) is:
<br /> [Y] = [F]/[A] = \mathrm{T}^{-2} \, \mathrm{L}^{-1} \, \mathrm{M} = \frac{[E_{0}]}{[a_{0}]^{3}}<br />
<br /> Y_{0} = \frac{27.2 \, \mathrm{eV} \times \frac{1.602 \times 10^{-19} \, \mathrm{J}}{1 \, \mathrm{eV}}}{(5.29 \times 10^{-11} \, \mathrm{m})^{3}}.<br />
I believe the answer to your question is:
<br /> Y = \frac{Y_{0}}{226}<br />
Where are you getting all the values for this equation? I apologize, but this is like reading a different language! I'm just not understanding where 27.2, 1.602, and 5.29 are taken from...
Look up the stress strain relationships for elastic materials where the stress (P/A) is linearly proportional to the strain (elongation/length). Watch your units.
I think I've figured it out! Thanks for your help. I posted another question and still haven't had any responses. I've been trying to research this question for a few days and still haven't a clue as to what needs to be done. Do any of you know what the heck this question is asking and how I go about solving it. (The book I have for my class has nothing like this in it, nor have I seen anything like this throughout the chapters I have studied).
A balance, the beam of which is 30 centimeters long and weighs 40 grams, is deflected through 1° by an excess of 1 milligram in one of the pans. What is the distance of the center of gravity of the beam below the central pivot?
Young’s Modulus, E= tensile stress/tensile strain= (F/Ao)/(∆L/Lo)
F= force applied to object= ma= mg= (12kg)(9.81m/s2)= 117 N
Ao= cross-sectional area through which force is applied= πr2= 2.8 x 10^-8
∆L= amount by which length of object changes= 0.008m
Lo= original length of the object= 0.25m
So, E= (mg/Ao)/(∆L/Lo)= (117N/2.8x10^-8)^2/(0.008m)(0.25m)= 0.0165 Gpa,
Gpa=gigapascals
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
