Young's slit experiment with single photons
In summary, Marilyn is having trouble understanding Young's slit experiment with single photons. She is confused by the popular science description that the photon interferes with itself, and believes that it is actually different photons interfering with each other. She also questions how the mathematical formalism of quantum mechanics can predict this phenomenon. However, Dale explains that a single photon can indeed interfere with itself, and that this is due to the fact that a photon is not a point-particle but rather a one-quantum Fock state of the quantized electromagnetic field. This explains the probability distribution observed in the interference pattern.
  • #36
Thank you all very much for your very informative answers !
I can't find these answers elsewhere.
I know this is all complicated, and as PeterDonis points out, everyday language can cause confusion.
It is not easy to develop an experiment like this because it requires a lot of theoretical knowledge, and to put it into practice, I imagine the work of precision and adjustment that it represents, and also its cost.
I don't know who can do this alone in his cellar !
Then, apparently, you have to know how to interpret the results which can be positive biases or negative biases !
It's really not easy, and all the people who work and think in this area have merit !
I need to reread all your answers, to review this video again, to take notes and to make a synthesis to see more clearly.
Cordially,
Marilyn
  • #37
WernerQH said:
I don't know what "real" single photons are. You always have to wait some time for a photon to be produced, although there are of course experiments where they are created very quickly. The photon concept applies to the absorption and emission of light, which occurs only in "lumps" having energy ## E = h\nu ##. The propagation of light, however, is well described as a wave phenomenon (Maxwell's equations).
A real single photon is a normalizable Fock state of exact photon number 1, i.e.,
$$|\Psi \rangle=\int_{\mathbb{R}^3} \mathrm{d}^3 k \sum_{\lambda=-1,1} A_{\lambda}(\vec{k}) \hat{a}^{\dagger}(\vec{k},\lambda) |\Omega \rangle,$$
where ##\lambda \in \{-1,1 \}## are helicities (polarizations) and ##|\Omega \rangle## is the photon vacuum state. It describes an (asymptotic) free photon, and ##A_{\lambda}(\vec{k})## are square-integrable functions such that
$$\int_{\mathbb{R}^3} \mathrm{d}^3 k |A_{\lambda}(\vec{k})|^2=1.$$
Photons never behave like massless point particles but as a quantum state of the electromagnetic field, i.e., as a wave. Particularly all the discussion about coherence, coherence lengths and times, etc. also apply to these single-photon states, and the interference patterns that can be measured by using very many single photons are those of the corresponding classical waves, reflecting the probability distributions for registering a photon at a given time and position of the detector (or a photoplate).
It hasn't been easy to produce true single-photon states. Unfortunately that's reflected by the inaccurate statement that you just have to use a very dim light source like a laser, but that doesn't produce true single-photon states but coherent states that are not eigenstates of the photon number. A very "dim" coherent state consists mostly of the vacuum, and the distribution of photon numbers is Poissonian. Although you can make the average photon number as small as you like (also below 1!), you never have a true single-photon state but a superposition of all number states, and for such a "dim coherent state" it's most probable to find no photon at all but some small probability to find 1, and even smaller probability to find 2, etc. photons.
Likes hutchphd, Marilyn67, gentzen and 1 other person
  • #38
Hello,
I just have one more question for you.
PeterDonis said:
More precisely, for most light sources it is very difficult to set up an experiment that will detect meaningful interference phenomena.
I know that commercially available small cheap laser pointers have much lower beam quality than a laser like helium neon laser or argon laser for example.
I myself own a small green laser pointer, class IIIb, (<20mW), 532 Nm.
If nothing other than the source is changed in the experience previously described on the link,
https://www.physicsforums.com/threads/how-big-is-a-photon-interesting-video.1005059/
but by replacing the neon helium laser with this type of laser pointer, will interference be observed as easily ?
Is the coherence length sufficient to observe interferences in the experiment setup depicted in the video ?
In advance, thank you for your response.
Cordially,
Marilyn
  • #39
For me, yes :wink:
  • #40
Probably not because the cheap laser pointer probably has a much shorter coherence length. It probably also has a wider frequency width in its beam (no laser is perfect so they all have some finite frequency width, but the narrower the width the easier it is to observe interference).
Likes vanhees71 and Marilyn67
  • #41
Thank you @PeterDonis ,
Your answer is interesting.
I didn't expect laser pointers with such poor quality..!
It would be interesting to repeat the experiment by modulating the distance of the second path to have an order of magnitude of the distance from which the results change... (a few decimetres, a few centimeters perhaps...)
See you soon,
Marilyn
  • #42
"Poor quality" is relative. Cheap laser pointers aren't designed to help you run interference experiments. :wink:
Likes vanhees71, PeroK and Marilyn67
  • #43
Yes, it's true
It's all the more interesting to try :wink:
(I've done this before with Young's slits, my laser pointer and a lens)
Cordially,
Marilyn
Likes vanhees71
  • #44
At school I did the experiment using a sodium flame, before the invention of the laser. We passed the light through a slit to create a degree of coherence.
  • #45
Hello @tech99 ,
Tell you about an experience with Young's slots ?
From what I understood at the beginning of the discussion, it's very easy to get visible interference with Young's slits because the path differences are very small at the point of impact.
I guess in the video setup a sodium flame would have given a diffuse pattern, right ?
Cordially,
Marilyn
  • #46
There is an experiment shown on this video using sunlight as the source.
The light is passed first through a slit to provide spatial coherence. It is just a question of making the geometry so that the path length differences from each edge of the first slit to the double slits are much less than a wavelength. The pattern is very similar to the laser result, but not quite as sharp. The frequency coherence issue causes the sunlight to give coloured fringes. We used sodium light, which is sufficiently monochromatic to give clear fringes.
Likes Marilyn67 and vanhees71
  • #47
Thanks @tech99 for your response,
I ask myself 2 questions that you may find silly :
1/ How to obtain such precision when we know that the dilation due to temperature changes and that the vibrations present in the environment are of an order of magnitude well above 1/2 micron ?
2/ Why such precision for Young's slit experiment ?
If the difference in path length from each edge of the first slit to the double slits is even a few percent, isn't the interference pattern just shifted across the screen to the right or left to compensate this difference ? :oops:
Cordially,
Marilyn
  • #48
The long triangle formed by the rays from each edge ensures that close tolerances are unnecessary. For instance, the (height - hypotenuse) is easily made much less than a micron. We do not require great precision.
  • #49
Ok, I understand the "how" but not the "why". :wink:
Indeed, to have interfringes "i" visible to the naked eye on the screen, a large length "D" and a small distance "a" between the two slits (i = λ.D/a) are required and here, "D" >> "a".
But we can imagine a much shorter triangle, and observe smaller interfringes i thanks to the equivalent of a microscope (ok it's more complicated, but a path difference less than the wavelength is not "fundamentally necessary", or is there another reason ?)
Is there a fundamental reason, or is it just a convenience to have wide interfringes ?
  • #50
When we used sodium light we used a traveling microscope (which we used to call a cathetometer) to observe the fringes. There is a trade-off between fringe spacing and brightness, and a laser is much brighter than a sodium source.
  • #51
The real world is much more complicated than the idealized two slits in a plane. In fact there are interferences from different numbers of wavelengths ("orders" of diffraction) that are more and more difficult to capture because they are typically finer detail. In fact an arbitrary object when illuminated appropriately will produce a very very complicated pattern of interferences on all scales. This is a hologram !
Likes tech99, vanhees71 and Marilyn67
  • #52
Thanks @tech99 for your very concise answer.
It's still instructive today to know how we did in the good old days and with hindsight, it gives good ideas for tomorrow !
Cordially,
Marilyn
  • #53
If you are looking for something to help you visualize single-photon interference in the double slit experiment, consider the following model. Imagine each possible state of the experiment's photon exists in a different world. So, in one world the photon traces a certain path to the detector, while in other worlds it traces a different path. Next, apply the uncertainty principle, which tells us that prior to observation we cannot be sure exactly which path a given photon will take, or in this model, exactly which world that photon occupies. When the experiment is performed, such uncertainty means each individual photon is not confined to anyone particular world, and thus is free to interact with other photons, the ones in other states/worlds, thus causing each individual photon's landing location to indicate interference has occurred.
  • Sad
  • Skeptical
Likes weirdoguy and PeroK
  • #54
That sounds like hocus pocus to me!
Likes Lord Jestocost, Nugatory and vanhees71
  • #55
Do you have a reference for this model? Or is it just your personal speculation? Personal speculations are off limits here.
This sounds somewhat like the Many Worlds Interpretation--which would, in itself, mean it is off limits in this particular thread, because discussions of particular QM interpretations belong in the interpretations subforum, not this one, and this thread is about a question in the context of basic QM without adopting any particular interpretation.
However, the resemblance is only "somewhat", since in the MWI, different "worlds" refers to different decoherent branches of the wave function. The parts of the wave function that refer to the photon going through different slits are not different decoherent branches, so they are not different "worlds" in the sense of the MWI. (The fact that the different parts of the wave function can "interact", combining to produce the final probability amplitudes at the detector, also means they aren't different "worlds" in the sense of the MWI, since different "worlds" in the MWI cannot interact.)
  • #56
It's much simpler. A single photon is still a certain state of an electromagnetic field (one-photon Fock state) and thus describes a wave, and in the double-slit experiment there's interference between the partial waves moving through either slit, which makes the interference pattern.
It's, however, different from the classical electromagnetic waves (which are quantum-field-theoretically described by so-called coherent states, which are other states of the electromagnetic field which do not have a specified number of photons; the photon number in a single-mode coherent state is Poisson distributed). A single-photon state means that you can only detect strictly one photon by, e.g., using the photo effect in the detector material, leading to absorption of this one photon and kicking out an electron, which can be used as a signal to detect the photon at the place of the detector. The meaning of the electromagnetic wave for a single photon is the probability distribution for detecting a photon at a given place and is identical with the intensity of this em. wave (i.e., the energy density), properly normalized such that the probabilities sum to 1.
Likes hutchphd and PeroK
  • #57
I was referring to the explanation of the miwoi model (a combination of Many Worlds and Uncertainty Principle). It's deceptively simple, yet is also consistent with other things quantum such as tunneling, Ehrenfest's theorem, zero-point energy, and more. The model's prediction that matter's gravitational field changes slightly upon decoherence subsequently gained support from the recent observation of such in colliding galaxies. This hints at a quantum role in dark matter/energy.
  • #58
This might not be responsive, but one thought after reading your first post @Marilyn67 - My understanding is that if there is no measurement, no wave collapse, then the way to think about it is the PROBABILITY WAVES of that single particle (not yet collapsed) go through both slits. It is those waves that interfere (or reinforce) each other as they interact on the other side of the slits.
Making one slit closer or further away will affect the interference pattern, but it will still be there (in absence of measurement).
Likes Marilyn67
  • #59
A different way to say the same thing - before collapse, the particle is still a wave, and that wave will take every possible path it can, as a wave. The wave taking those different paths is causing the interference.
Question for someone: if you remove one slit, so you have a single slit, will an interference pattern be shown? I could have sworn I read somewhere that it would still show up, but that would not make sense to me. How could there be interference where the wave could take only one possible path?
  • Skeptical
Likes Marilyn67 and PeroK
  • #60
Yes. The single-slit diffraction pattern is caused by interference of waves that pass through different parts of the slit, across its width.
[added] The general two-slit diffraction pattern combines the effects of interference between the two slits, and interference between the different parts of each slit.
As the slits become narrower, while keeping them the same distance apart, the central maximum of the single-slit pattern spreads out and eventually fills the "field of view" so that you see only the classic two-slit interference pattern.
Note the scales are different in the two two-slit patterns linked above. If the slits have the same separation in the two patterns (with only their width being different), the peaks in the two-slit interference pattern are the same width as the narrow peaks in the two-slit diffraction pattern.
  • #61
One can save a lot of confusion when stating right from the beginning that a "quantum" is described by quantum theory, and they have neither classical particle nor classical wave properties. There's also no wave-particle dualism, which was part of the socalled "old quantum theory", which was indeed very confusing, because it was not a self-consistent theory for the behavior of matter. Modern quantum theory resolves all these quibbles by the probabilistic interpretation of the quantum state a la Born.
In addition the most flexible formulation of (many-body) quantum theory for both the non-relativistic and the relativistic theory is the quantum-field theoretical formulation (often called "2nd quantization", although there's only one quantum theory, and for non-relativistic QT there's a "1st-quantization formalism" at best applicable in some non-relativistic limit). Accordingly you are usually better off when thinking in terms of field theories/waves when thinking about a situation in a heuristic way.
Likes Marilyn67
  • #62
HomesliceMMA said:
A different way to say the same thing - before collapse, the particle is still a wave….
And it is a wave after collapse too, just a different one - that’s why we can get interference even in the single-slit case, as explained by @jtbell in post #60.
The idea that sometimes it’s a particle and sometimes it’s a wave, that the wave turns into a particle when the wave function collapses….These ideas were discarded almost a century ago when the modern theory of quantum mechanics was developed. They are stuff that you are going to have to unlearn.
  • #63
Hello @jtbell,
Your answer is really very instructive and well argued.
Thank you for your link to this site which is a gold mine of information !
The question concerning the possibility of observing interference by closing the second slit was therefore relevant !
I realize that in popularization, to say that closing a slit makes the interference fringes disappear is an "abuse of language" :
In fact, what disappears is the previous interference pattern (with small inter-fringes), and it gives way to another interference pattern, on a larger scale, a scale so large that this pattern can go unnoticed if it isn't observed correctly, in particular the central fringe which looks deceptively like the classic diffuse pattern if it isn't observed with good precision !
It's very interesting, and it leads me directly to the corollary with the MZI mentioned in my message #20, where we observe an interference pattern on a screen (thanks to lenses) on each side of the quantum eraser when the two paths are taken without observing "which path" is taken.
You guess my question :
Transposed to the MZI, does the phenomenon described in Young's slits (1 closed slit) have its equivalent if one of the two paths of the MZI is closed ?
Is there really no interference on either side of the quantum eraser if one arm is blocked, or does a comparable phenomenon occur with interferences on another scale, which can go unnoticed ?
Cordially,
Marilyn
  • #64
I've demonstrated this many times in undergraduate laboratories, by placing two slits in the path of a laser beam (which produces the two-slit diffraction pattern), then carefully sliding a sharp edge like a razor blade behind one of the slits, leaving the other one open. The gaps between the narrow interference peaks "fill in", leaving the broad diffraction pattern.
I've just now remembered that the site where I got my links has a side-by-side illustration on a different page.
Likes Marilyn67, Vanadium 50, vanhees71 and 1 other person
  • #65
Thank you jtbell for your explanation (still trying to understand the part you added) and thank you Nugatory! But Nugatory, you said:
"The idea that sometimes it’s a particle and sometimes it’s a wave, that the wave turns into a particle when the wave function collapses….These ideas were discarded almost a century ago when the modern theory of quantum mechanics was developed. They are stuff that you are going to have to unlearn."
So wait a sec, what am I going to have to unlearn? I mean, its always a particle, but is it not initially a wave, which, upon a measurement or other sufficient disturbance (which is still a gray area), show up as a discrete particle somewhere, based on its probability wave? What part of that is not consistent with current thinking?
Thanks guys!!!
  • #66
No, it isn't. That's one of the things you need to unlearn. Quantum objects aren't particles and they aren't waves; they are quantum objects. Some aspects of their behavior are similar to the behavior of particles, and other aspects are similar to the behavior of waves. But they are not particles or waves.
Likes Marilyn67, hutchphd and vanhees71
  • #67
jtbell, when you say:
"As the slits become narrower, while keeping them the same distance apart, the central maximum of the single-slit pattern spreads out and eventually fills the "field of view" so that you see only the classic two-slit interference pattern."
That sounds weird to me. What is going on there? I would have thought as you narrow the slit in a single-slit test, the interference pattern would get a little bit narrower. I.E. you are narrowing the path the wave can take through the slit, so the interference pattern should shrink. Maybe not go away, since its a wave, but shrink consistent with the slit shrinking. Are you say it actually broadens as you narrow the slit?
Thanks again!!!
Likes Nugatory
  • #68
Are we talking semantics here? If they are not "particles" or "waves", is it true to say they "act as" particles or waves (after and before a decoherence event or whatever it is called, respectively)? Or is even that wrong? If that is right, is there really any difference, other than semantics, between the two vernaculars?
Thanks!
  • #69
No, we are correcting a common misconception. "Particle" and "wave" are classical concepts. Quantum objects are not classical. You can't expect classical concepts to apply to them.
If you just want to point at particular aspects of experimental results that look like particle or wave behavior, yes, you can say that. But any such statements will be limited.
Yes: thinking of quantum objects as particles, or waves, or "waves that sometimes turn into particles", will mean you end up getting wrong answers. (You give an example of this in post #67.) If you really want to learn the right answers, you have to stop thinking of quantum objects as particles or waves or any other classical concept, and learn the theory, quantum mechanics, that makes accurate predictions about what these quantum objects actually do.
  • #70
PeterDonis said:
No, we are correcting a common misconception. "Particle" and "wave" are classical concepts. Quantum objects are not classical. You can't expect classical concepts to apply to them.If you just want to point at particular aspects of experimental results that look like particle or wave behavior, yes, you can say that. But any such statements will be limited.Yes: thinking of quantum objects as particles, or waves, or "waves that sometimes turn into particles", will mean you end up getting wrong answers. (You give an example of this in post #67.) If you really want to learn the right answers, you have to stop thinking of quantum objects as particles or waves or any other classical concept, and learn the theory, quantum mechanics, that makes accurate predictions about what these quantum objects actually do.
Understood (I think) PeterDonis, just trying to learn! So would a more/less correct statement be: Things we think of as photons and electrons (and I guess any classical "elementary particles" and maybe any other mass in classical sense?) is neither a particle nor a wave, but behaves either as a wave (before a decoherence event or whatever its called) or as a particle (after a decoherence event)? Something like that?
Thank you!
