MHB Zero's question at Yahoo Answers regarding interpolating to find a z-score
  • Thread starter Thread starter MarkFL
The discussion centers on how to approximate a z-score for an area of 2.3756 using interpolation. The z-scores for areas 2.37 and 2.38 are identified as 0.4911 and 0.4913, respectively. The interpolation method is demonstrated through a ratio calculation, yielding an approximate z-score of 0.491212. However, a participant points out a fundamental error, noting that probabilities should range from 0 to 1 while z-scores can be any real number, suggesting a mix-up in the values presented. The conversation emphasizes the importance of correctly interpreting z-scores and probabilities in statistical contexts.
MarkFL
MHB
Here is the question:
Z score approximation ?
How do you approximate a z score when you have something like 2.3756Additional Details: how do you interlope ?
Here is a link to the question:
Z score approximation ? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Re: Zero's quastion at Yahoo! answers regarding interpolating to find a z-score
Hello Zero,
Consulting a table, we find that the $z$-score associated with an area of 2.37 is 0.4911 and for an area of 2.38 is 0.4913.
To interpolate, we may simply use the ratio:
$$\frac{2.38-2.37}{0.4913-0.4911}=\frac{2.3756-2.37}{\Delta z}$$
$$\frac{0.01}{0.0002}=\frac{0.0056}{\Delta z}$$
$$50=\frac{7}{1250\Delta z}$$
$$\Delta z=\frac{7}{62500}=0.000112$$
And so, we may state:
$$z\approx0.4911+\Delta z=0.491212$$
Using numeric integration, we find:
$$z=\frac{1}{\sqrt{2\pi}}\int_0^{2.3756}e^{-\frac{x^2}{2}}\,dx\approx0.49124$$
To Zero and any other guests viewing this topic, I invite and encourage you to register and post any other normal distribution question in our http://www.mathhelpboards.com/f23/ forum.
Best Regards,
Mark.
MarkFL said:
Hello Zero,
Best Regards,
Mark.
There is something wrong here, probabilities (areas) are in the range 0 to 1 and z scores can be any real number, here they look the other way around. (Which is what the integral at the end would be saying if the z on the left hand side were replaced with p and the variable of integration were z.)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
