Why centripetal accel is from an internal force?
In summary, the conversation discusses the concept of internal and external forces, as well as the conditions for static equilibrium. It is noted that the determination of whether a force is internal or external is subjective and dependent on the chosen system boundary. The equations for static equilibrium, sum of forces equals zero and sum of moments equals zero, are also mentioned. The concept of stability is briefly touched upon, with an example given of a cube on a cylinder and its stability depending on the size of the cylinder radius. The potential energy of the system is also mentioned as a factor in determining stability.
makeAwish
128
Can i ask sth?
Usually what type of forces can be considered as external force, besides friction?
And, for static equilibrium, do we only use the eqn: sum of forces equals zero, or we can also apply sum of moments equals zero?
Thanks!
There is some arbitrariness in defining whether a force is internal or external, because the boundaries of the system under study are in the eye of the beholder. Typically, the entirety of a solid object is within the boundary of a system, so any forces between parts of a solid object would be internal. Centripetal forces on a spinning solid body come from the electrostatic forces holding the object rigid. So typically, centripetal forces are internal, unless some bizarre and unusual boundary for the the system was chosen. It's hard to see the usefulness of such a choice.
Any forces between an object inside the system boundary and outside the system boundary are considered external. These could be anything from magnetism to gravity to whatever.
If I understand things correctly, to have static equilibrium, the sum of the forces and the sum of the torques must be zero.
Say, an object on a table and my system is the book and table, the book's and the table's weights and the normal reaction forces are considered to be internal or external forces?
And what if my system is just the book, the same forces are external?
Static eqm means the object not moving..
But sum of the forces equals zero means acceleration equals to zero rite?
Am i right to say zero accel generally don't mean velocity equals to zero, but for static eqm, though sum of the forces equal to zero, the obj in fact is not moving?
Good questions! You tell me. In both cases, the Earth is outside of your system boundary, so would gravity be external?
What about the contact (or normal) forces between the book and the table. When do such forces cross the system boundary and when do they not?
It's not obvious to me that static equilibrium really means that the object is not moving. I can build a house of cards while riding on a smooth train, but I (and my deck of cards) are still moving.
oh.. so in both cases, weight is external force?
if my system is just the book, normal forces are external but if my sys is both book and table, they are internal?
friction is it always considered as external? say i push the book along table and sys is both book and table..
even if i take my sys as the book only, friction is external too?
hmm. but i tot static means object is at rest?
Then for both static and dynamic eqm, the equations are the same? (sum of forces equals zero, and sum of moments equals zero)
There are two type of static equilibrium; stable and quasi stable. Consider a solid cube of side a balanced on a cylinder of radius b. When a is small, the system is stable, when it is larger than a certain value it is quasistable; any perturbation will make the cube tip over.
this is abt stability is it?
hmm.. i still don't understand..
Work out the stability equations for a cube with sides = 30 cm, balanced on a cylinder with radius 5 cm, perturb it and see what happens. Then increase the size of the cylinder radius to 50 cm.
but i haven't learn abt stability yet.. =x i don't know the equations..
Work out the potential energy of my example of cube balanced on cylinder as a function of a. b. and tilt angle of cube, and if it increases as tilt angle increases, it is absolutely stable, and if it decreases, the cube is quasistable and will fall off if pushed.
Related to Why centripetal accel is from an internal force?
1. Why is centripetal acceleration always directed towards the center of the circle?
The centripetal acceleration is always directed towards the center of the circle because it is caused by a centripetal force, which is directed towards the center. This force is responsible for keeping an object moving in a circular path.
2. What is the difference between centripetal acceleration and centrifugal acceleration?
Centripetal acceleration is the acceleration experienced by an object moving in a circular path, whereas centrifugal acceleration is the apparent outward force experienced by an object in circular motion. Centrifugal acceleration is a result of inertia, while centripetal acceleration is a result of a centripetal force acting on the object.
3. How does centripetal acceleration relate to the speed of the object?
The magnitude of centripetal acceleration is directly proportional to the speed of the object. This means that the faster an object moves in a circular path, the greater the magnitude of its centripetal acceleration. However, the direction of the centripetal acceleration will always be towards the center of the circle.
4. Is centripetal acceleration a real force?
No, centripetal acceleration is not a real force. It is a result of the centripetal force acting on an object. The centripetal force is the real force that causes the acceleration, while the acceleration itself is just a change in velocity.
5. Can centripetal acceleration be negative?
Yes, centripetal acceleration can be negative. This happens when the direction of the velocity and the direction of the centripetal force are opposite, causing the object to slow down. However, the magnitude of the acceleration will still be positive, as it is always directed towards the center of the circle.
  • Mechanics
