- #1
universal_101
- 325
- 3
Most of the people here, who responded to the last thread posted by me, may think of me as someone who does not want to understand Relativity, and instead is just barking at the wrong tree. But I'm posting the same Logical contradiction of using Lorentz Transformation to conclude Time Dilation of unstable moving particles with the definition of physical law.
But first, let me make sure that people here understand the basic nature of the problem I'm encountering with the relativity of transformations and Physical laws.
As the topic suggests, the problem starts with the definition of physical laws and transformation itself. Let me make it more clear by using an example and the respective definitions.
A physical law must be invariant under a transformation from one observer to another. In other words, it is independent of who is observing it. the conclusion of using a physical law for a physical process must be same for all observers(inertial).
Whereas, a transformation, let's consider a co-ordinate transform in geometry first, then we can simply extend the concept for the Lorentz Transformation. In geometry the shape of any object(circle, parabola, line) does not depend on the position of the origin of the co-ordinate system, even though the co-ordinates(x,y,z) of these objects can change.
The same applies to the Lorentz transformation, the outcome of a physical law cannot change under transformation, even though the parameters of the equation governing the physical law changes after the transformation.
Both of these(LT and Physical law), can be analogously visualized in the following example.
Consider a live play in a large auditorium, Now the parts of the play that shows what happens to the characters in the play, can be considered as a physical law(for example, a characters death). Whereas, the observation from different positions of the auditorium can be calculated as the transformation of the events in play for different observers. That is, everybody sees the death of the character but their view can be different depending on their positions.
Now, coming back to my original question,
If the number of unstable particles reaching the Earth is invariant under Lorentz transformation. Then this phenomena must be explained by a physical law and not by the transformation itself. Since, a transformation cannot keep the numbers invariant if this phenomena were to be actually explained by the transformation of observers. But as we all know, the transformation around this phenomena does keep the numbers invariant must imply that this phenomena is governed by a physical law and not by the transformation.
So,What is wrong with the above Logical argument?
Thanks,
Thanks,
