Transformation Vs. Physical Law
In summary, the conversation discusses the use of Lorentz Transformation in understanding Time Dilation of unstable particles. The speaker argues that this phenomenon should be explained by a physical law rather than the transformation itself. They provide an example of a play in an auditorium to illustrate the concept of physical laws and transformations. They also mention the invariance of physical laws under Lorentz Transformation and how it predicts the same outcome for different observers. However, the speaker believes that there is no physical law that explains Time Dilation of unstable particles and it is instead being explained by the transformation. They also mention the change in shape of objects under different frames and how this is different from the Lorentz transformation.
  • #211
harrylin said:
Then the issue is not really in the headline of your thread, "Transformation Vs. Physical Law"?
Well the headline transformation is Lorentz and not Galelien. And it makes me doubt how much of my point of view, or my problem, do you understand.
harrylin said:
?? I see nowhere where I suggested that Poincare was incorrect. What made you think so? Lorentz, Einstein and likely everyone else agreed with his criticism. Some people even consider him to be the real inventor of SR (see for example http://en.wikipedia.org/wiki/Henri_Poincaré#Assessments for an entry point to the debate).
Seems like I misinterpreted your post there, but then what was your intent.
harrylin said:
Maybe you are incorrect about what? You presented a point of view with which half of the people here seem to agree as well as a few erroneous claims that were debunked without comment by you (apparently you don't understand your errors). It doesn't trouble me much if a theoretical effect is too small to be directly measured with current technology (I already referred you to the first indirect experiment). That gives some slack for possible alternative theories, but very little.
As I stated several times, Length contraction must be a physical effect if Time Dilation of Muons were to be explained using Minkowski spacetime, if you disagree please say yes or no.
And No, any indirect experiment will not do, for the same reason. But when you say " a small theoretical effect" , it makes me question, if we can easily measure the Time Dilation and increased mass or relativistic energy, then how come Length contraction is a small effect to detect.
And I don't want to talk about alternate theories, but would certainly like to know, how can one understand all the effects that are present and absent in electrodynamics.
harrylin said:
Do you think that Newton should have been troubled by the fact that he could not test his theory to very high precision, so that he could not detect its flaws as we can nowadays? Most people are happy to have a better theory than before, and that works rather well.
I think Yes, Newton should have been troubled if his equations would have been suggesting the presence of an effect which he was unable to confirm experimentally or observations(for more than 100 Years). But since there was No problem of that sort, it all went great.
  • #212
That's perhaps the problem: your title is, as I stated "Re: Transformation Vs. Physical Law" and not as you state, "Lorentz and not Galelien" - as you can see when you look at the top of this page?!
I showed you that your claim that "Special relativity is not about the electromagnetism but it's transformation" was erroneous, by proving that, as I wrote, "It's about both the physical laws and the resulting transformation equations".
Yes and I even gave you a link to very strong indirect evidence for length contraction. Surely you know the evidence for clock slowdown. If you disagree, please tell what theory explains the Kennedy Thorndike experiment with time dilation but without length contraction.
What reason? Any indirect experiment will do for the reason that I just gave.
Plug in the numbers and you find out yourself. In addition, clocks can be made very stable and they accumulate time and the dynamic mass of small particles can easily be detected in particle experiments, but how would you detect their length? And as all moving lengths measurements are somewhat indirect, what kind of experiment would you consider sufficiently direct? Anyway, a theory is appreciated for its predictions that do have practical use, and not for predictions that don't have practical use.
[..] I think Yes, Newton should have been troubled if his equations would have been suggesting the presence of an effect which he was unable to confirm experimentally or observations(for more than 100 Years). But since there was No problem of that sort, it all went great.
That's not what I meant. Newton made assumptions which we now know to be slightly wrong, as they are only accurate at low speeds while he assumed that it was valid for all speeds. Should he have been troubled by the fact that he could not fully verify his theory?
  • #213
You haven't made clear how you think "physical effect" differs from any other kind of effect, what exactly do you mean by that phrase?
They are all small effects because usually speeds are small compared to the speed of light but all can be measured. As more than one person has said before, length contraction is directly measured by the Michelson Morley experiment.
They can all be understood as geometric effects in Minkowski spacetime but it is not clear if you include those in your term "physical effects".
I asked before but you never replied, if one person walks directly from A to C while another goes via B and they have the same stride length, they will take a different number of strides. What is your understanding of that physical effect, or do you not consider the reason to be "physical"?
  • #214
Austin0 said:
Of course within a frame every possible coordinate system will have a relevant version of the Minkoiwski metric. We are in the middle of a discussion regarding the -version for cylindrical coordinates right now. So it should be obvious that this is not what I meant.
Within a frame transformation of events between different coordinate systems does not invlove the Minkowski metric.
That's not correct. Fundamentally, a metric tensor g(A,B) is a function that takes two vectors A and B and returns a real number, the "dot-product" of A and B. This meaning does not in any way depend on frames, or transformations. The metric determines the length of a vector via:
length(A) = √g(A,A)
If you have two neighboring events e1 and e2, then there is an associated vector, the spacetime separation between the events dX. Then the invariant distance between the events is given by:
ds = √|g(dX,dX)|
The meaning of the invariant interval has nothing to do with frames, or coordinate systems, or transformations. It's a geometric quantity, like the length of a line segment. As a matter of fact, in the specific case where e1 and e2 take place at the same time in some frame F, ds is equal to the distance between those events, as measured in that frame.
  • #215
A Physical effect is that which can be measured independently, that is the to observe the effect we don't need to include any assumptions or the indirect ways, which is done in the MMX experiment and it's extended version, the KT experiment.
No, MMX does not prove/verify anything other than the "Non-Existence of aether". Any thing else that you say it proves is just the basis of the theory(SR) in order to understand the Experiment. That is, length contraction in MMX is part of the theory itself and not the proof of it.
If you reread the first few pages of the thread then I think, it would be clear that I'm questioning the use of transformation to explain Time Dilation of Muons, which is a physical effect.
As long as the difference in the number of strides or the path can be measured independently of everything else, it is a physical effect.
  • #216
This discussion has gone on for a long time, so I don't think there is much hope that anything I could say will clear things up, if they haven't been cleared up already. But I disagree with your way of putting things.
The physical effect is that in the frame of the muons, the number of muons left after T seconds is given by 2-T/τ, where τ is the half-life of the muon.
Lorentz transformations come into play because you want to calculate T: how many seconds have elapsed in the frame of the muons? If you know that the muon went from x1 at time t1 to x2 at time t2, then you compute T via:
T = √(δt2 - 1/c2 δx2)
where δx = x2 - x1, and δt = t2 - t1.
This is a geometric computation, analogous to the case in Euclidean geometry: A line segment runs from the point (x1, y1) to the point (x2, y2). You calculate the length L via:
L = √(δx2 + 2 δy2)
where δx = x2 - x1, and δy = y2 - y1.
  • #217
universal_101 said:
A Physical effect is that which can be measured independently, that is the to observe the effect we don't need to include any assumptions or the indirect ways, which is done in the MMX experiment and it's extended version, the KT experiment. [..]
Again: what kind of moving length measurement would satisfy your desire?
If you reread the first few pages of the thread then I think, it would be clear that I'm questioning the use of transformation to explain Time Dilation of Muons, which is a physical effect. [..]
At least we solved that issue - you don't need to think that transformations "explain" physical effects. :-p
  • #218
I don't need to be satisfied, but it is very easy to see that we don't have any direct confirmation on Length contraction, as I posted earlier.
"No, MMX does not prove/verify anything other than the "Non-Existence of aether". Any thing else that you say it proves is just the basis of the theory(SR) in order to understand the Experiment. That is, length contraction in MMX is part of the theory itself and not the proof of it."
No, it is not solved, and by the way what do you think causes the relativistic physical effects, spacetime, metrics (if not transformations) !?
  • #219
Measurements always relay on some kind of interpretation. It can only be more primitive or more advanced but it is always there.
So are you sure that the answer you want to get is possible at all?
Speaking about physical effects. When we accelerate body or particle or whatever our experience says that it happens in single particular way (we assume certain level of idealisation here of course, we do not talk about car crash tests). But if we ask why acceleration of body happens in this particular way we have to allow other hypothetical ways how this could happen.
So can you say what other hypothetical ways for (physical) transformation of body undergoing acceleration this physical law should exclude?
  • #220
universal_101 said:
[..] It is very easy to see that we don't have any direct confirmation on Length contraction, as I posted earlier. [..]
And as I posted earlier, I first asked you what you would consider a "direct confirmation" of length contraction. It may be that what you ask for is even conceptually an impossibility - like saying that no square ball has been found (in which case we should say "so what"). Or, alternatively, it could be that experimental evidence does exist that you would find sufficiently "direct". As long as you don't specify it, we can't really help you with that.
Hmm that's strange, as several times I as well as several others actually agreed with your opinion in your first post - see for example my posts #95 and #120. To recapitulate:
You:
"If the number of unstable particles reaching the Earth is invariant under Lorentz transformation. Then this phenomena must be explained by a physical law and not by the transformation itself. Since, a transformation cannot keep the numbers invariant if this phenomena were to be actually explained by the transformation of observers. But as we all know, the transformation around this phenomena does keep the numbers invariant must imply that this phenomena is governed by a physical law and not by the transformation."
Me:
#95 sure the transformation equations provide us conditions that physical laws must conform with; or inversely, physical laws make that the transformation equations work. And that is already the case with classical (Newtonian) mechanics.
#120 In other words (your words!), one may hold the opinion that this phenomenon is governed by a physical law and not by a transformation between points of view. This physical law is a necessary requirement for the transformation equations to work.
#218 you don't need to think that transformations "explain" physical effects.
As to the question what causes relativistic physical effects, that's inherently the same question as what causes physical phenomena, including electromagnetism. And that's a field of speculation and perhaps even more of personal opinion (or philosophy). It's not scientifically relevant what someone's personal opinion is but sometimes physicsforums has polls about such opinions (should we have one now? how to set it up? :-p). I've seen such interpretations as "it's just the way nature is"(shut up and calculate), "it's due to the relativity principle/the Lorentz transformation"(mathematical interpretation), "it's caused by Spacetime"(geometric or block universe interpretation) or "it's caused by the Vacuum"(ether interpretation), and no doubt there are more.
  • #221
Austin0 said:
Wouldn't it be more correct to say it was true in general but not necessarily true in certain limited cases like rotating frames
Sorry about that, it is a bit of scientific jargon, but the phrase "in general" means "in the most general case", or in other words, something which is true "in general" is always true. What you mean is "typically", which is something that is true in the most common or usual case, but may not be true in some exceptional cases. Something which is true "in general" is true both in the typical case and also in the exceptional cases.
Austin0 said:
We are talking about SR , inertial frames, Not GR or accelerating frames which are outside the topic of this thread and discussion.
I wasn't. For a law to be a law it needs to be true in general, not just in special cases. I.e. a law of physics should be true even in the presence of gravitation and even in accelerating frames.
See also http://math.ucr.edu/home/baez/physics/Relativity/SR/acceleration.html regarding SR and accelerating frames.
  • #222
Then there are no physical effects. Nothing can be measured independently.
Your basic concern of this whole thread seems to be that some things are more conveniently described in terms of a transformation. We have a set of equations called laws of physics. Those equations have a large variety of features. Some experiments are sensitive only to a small subset of those features, so they can be explained by reference only to those features. Notable examples are conservation principles and transformation symmetries.
Just because you can explain some given experiment using one of these principles or symmetries does not imply that the laws of physics are flawed.
  • #223
Your basic concern of this whole thread seems to be that some things are more conveniently described in terms of a transformation. We have a set of equations called laws of physics. Those equations have a large variety of features. Some experiments are sensitive only to a small subset of those features, so they can be explained by reference to those features. Notable examples are conservation principles and transformation symmetries. Just because you can explain some given experiment using one of these principles or symmetries does not imply that the laws of physics are flawed.
I think that the way that reasoning in relativity works is often like this:
  • The laws of physics have the same form in any inertial coordinate system.
  • Therefore, choose a coordinate system that makes your particular problem easiest to solve.
  • Then, transform the answer into whichever coordinate system you want the answer in.
universal_101 seems to think that because you solve the problem using transformations, that you are using transformations instead of physical laws to solve the problem. That's not true at all.
  • #224
Ofcourse, it should work like this, but we are not using it like this when we are explaining Muons and motion, consider the following reasoning and assertion.
  • Since, Number of Muons reaching Earth is invariant, and therefore, any law that explains this invariant event, must not be dependent on any transformation tool. {Yes or No}
  • If Yes , Gamma factor is used to explain this invariant physical effect. {Yes or No}
  • If Yes , Gamma factor is a transformation tool in Special relativity. {Yes or No}
This explains the use of a transformation tool for an invariant physical effect, to which I have problem understanding.
In case, you still think one of the above points is NO, let's discuss it.
  • #225
The adjective independently was used to reflect the invariant nature of the events. And should not be confused with the dependence on the equipment.
Therefore, Ratio of the Number of Muons, starting from ionosphere to reaching Earth, can be measured independently or as invariant.
Or, an Experiment done in lab, the number of Muons created at one end and the number of Muons reaching the other end can be measured, independently or as invariant.
  • #226
Your "therefore" doesn't make sense to me, and your last point misses the point which we made that gamma is contained in the transformation laws because it is also part of natural law. I tried to explain that to you by mentioning the classical transformation laws, but apparently it needs to be not just mentioned but rubbed in:
According to your reasoning, in classical mechanics:
  • If Yes , factor 1 is used to explain this invariant physical effect. {Yes or No}
  • If Yes , factor 1 is a transformation tool in Classical relativity. {Yes or No}
What would you answer?
  • #227
If classical relativity stands for Galilean relativity, then it simply cannot/does not explain the Number of Muons reaching Earth. That's why we use Special relativity and its transformations.
  • #228
No, the logical deduction from that is that any use of a transformation tool must keep the number the same. That is different from suggesting that the tool cannot be used.
  • If Yes , ...[/QUOTE]
Not applicable.
Not applicable.
By all means.
  • #229
That's a difficult definition. If I boil watter in a kettle, does it's temperature rise? I could measure it with a termometer but then I am inferring a rise of temperature indirectly from the expansion of a column of red-dyed fluid.
In the MMX, there is nothing more indirect than that, we measure the length of an arm by comparing the time it takes light to travel from one end to the other and back. This is not dependent on a transform, the measurements all take place in the rest frame of the equipment.
Not at all, you get the same conclusion using either SR or LET.
That's somewhat different from the way I've seen the term used before. The same is true of the changes in coordinate values resulting from the use of the Lorentz Transforms so by your definition, the gamma factor is a "physical" effect. The analogy of taking different paths works quite well (other than for the sign in the equations) for understanding SR, it's just extended to 4D instead of 3D so whatever categorisation you think applies to this analogy probably applies to the Lorentz Transforms too.
  • #230
Also according to classical mechanics (with "Galilean relativity") there should be an invariant number of muons arriving at the Earth. But as that distracts you from my question, we can replace it with the number of raindrops reaching the earth. Thus, again:
Since, Number of Raindrops reaching Earth is invariant, and therefore, any law that explains this invariant event, must not be dependent on any transformation tool. {Yes or No}
  • #231
harrylin said:
Also according to classical mechanics there is an invariant number of muons arriving at the Earth. But as that distracts you from my question, we can replace it with the number of raindrops reaching the earth. Thus, again:
The number of raindrops, which started their journey are same which reach to the Earth surface, but with Muons this is not the case, they seem to change their half-life when they are moving to reach the Earth.
That is, I'm not questioning a particular number of Muons, but their ratio to the number of Muons which started their journey to the number of Muons which reached the Earth.
It is the ratio which is in question, not the numbers at one particular stage.
  • #232
Does that mean, there is nothing wrong with, the use of a transformation tool to explain number of Muons reaching Earth ?
Well if that is what you are suggesting, then aside from mathematics, where is the physics that let you use a transformation tool to explain a physical effect.
Or do you even doubt the physicality/invariant property of the number of Muons reaching Earth, itself !?
  • #233
In the part on which I commented you were not questioning the muons ratio but the gamma factor in the context of transformation vs. physical law. You suggested that the gamma factor can't be part of a physical law because it's also part of the transformation equations. So, what about the factor 1 in classical mechanics, how can that be part of physical law if it's also part of the transformation equations?
  • #234
I'm quoting my previous post, which clarifies the above confusion.
LET cannot be applied to MMX, because it is not falsifiable, i.e. we cannot detect ether.
And Nobody likes a physics theory based on purely mathematics.
Exactly, I'm suggesting that gamma factor is a physical effect, and there seem to be experimental indication of it. (The paper I quoted earlier)
  • #235
harrylin said:
In the part on which I commented you were not questioning the muons ratio but the gamma factor in the context of transformation vs. physical law. You suggested that the gamma factor can't be part of a physical law because it's also part of the transformation equations. So, what about the factor 1 in classical mechanics, how can that be part of physical law if it's also part of the transformation equations? Please prove that you're not just trolling.
How in the world are you going to separate the ratio of Muons and the gamma factor. This is exactly what Dalespam was arguing and presenting his mathematics for, to prove they are unrelated, but apparently did not go far.
The ratio of Muons is defined by gamma factor,
The only way I know of producing gamma factor is using Transformations(Lorentz).
Whereas, I'm suggesting that gamma factor must be introduced by a physical law and not by a transformation.
That is, it just happens to be that gamma factor of the Lorentz transformation, is the same gamma factor which should come from a physical law.
So, we should have a gamma factor introduced by an physical law(which ofcourse depends on relative motion), and not by a transformation.
I don't know if I gave enough proof !
  • #236
They are not unrelated as I and others showed. And I simply tried to make clear to you how your questions don't make sense to me by asking the same about classical physics, in order for you to clarify what you mean, show that you can be consistent, and hopefully correct your fuzzy questions. But apparently you simply refuse to clarify your questions.
That's not needed at all, as I stressed in a number of posts and others also stressed this.
Don't you know the gamma time dilation factor expressed as law for physical processes such as clocks and muons?
It has been agreed and clarified many times in this thread that it makes sense to introduce the gamma factor as part of physical laws. By the way, that already was done in 1888 for the fields of charged particles.
No, exactly as I stressed in my last posts: it not "just happens to be" that factor 1 of the Galilean transformation, is the same factor 1 which also comes from a classical physical law. Different physical laws cause different transformations, and this has been clarified several times now (as much as possible without you doing any math).
That's a matter of philosophy, as I stressed in one or two earlier posts. No proof needed or possible for philosophy. While you and I find it logical the brains of some other people are wired differently. And the math doesn't tell you.
  • #237
universal_101 said:
Ofcourse, it should work like this, but we are not using it like this when we are explaining Muons and motion.
I think the questions are based on a misunderstanding. If I had to answer yes/no, I would say "no", "no", "no". Transformations can certainly be used for explanatory purposes--otherwise, they wouldn't be used in science. If I want to explain how a 2-meter board can fit through a 0.5 meter doorway, I would use geometry; I would show that what's important is not the length of the board, but the projection of that length onto the width of the doorway. Computing that projection involves the angle between the board and the width of the doorway. Alternatively, we could talk about this in terms of a transformation between two coordinate systems: one in which the board is aligned in the +x direction, and a second one in which the width of the doorway is aligned in the +x direction.
There is a similar type projection going on in the problem of muon decay. There are two "worldlines" that are relevant: that of the muons and that of the Earth. The amount of muons left at any time is a function of the "length" of the worldline of the muons. To compute what this elapsed time is, according to the Earth, you have to compute the projection of the muons' worldline onto the Earth's worldline.
In every SR problem, there is a part that is physical, having to do with forces and clock rates and so forth. The half-life of a muon is such a physical effect. Then there is a part that is geometric, having to do with the projection of some quantity onto a particular worldline, or something similar.
gamma plays the same role in relativity that cos(theta) plays in Euclidean geometry. It's involved whenever is projecting one worldline onto another.
  • #238
The gamma factor comes up in the geometry of spacetime, in exactly the same way that cos(θ) comes up in Euclidean geometry. If two straight sticks make an angle θ with respect to each other, then the projection of the length of one stick onto the other stick involves cos(θ).
If in a relativity problem, two worldlines have a different orientation in spacetime, then the projection of the length of one onto the other involves the factor gamma. It's really about projections, not about transformations. You can use projections to create a coordinate transformation, but projections make sense even before you choose a coordinate system.
  • #239
That is indeed reasonable, but the correct adjective is "invariant", not "independent".
The muon ratios you mention are invariant and are given by the law I cited at the beginning of the thread, without using any transform. So your question seems to have been resolved more than a hundred posts ago.
  • #240
See post 154 where I derive gamma directly from the metric without a Lorentz transform.
  • #241
Checking for it, I see that you already qualitatively clarified the whole matter in post #7 of this thread - that's more than 200 posts ago - and you stated that you already did so in an earlier thread. :-p
And concerning the time tau, I thought that I gave that but if not, here it is for universal as given in 1905:
"the time marked by the [moving] clock (viewed in the stationary system) is slow [on the reference clock] by 1-√(1-v2/c2) seconds per second, or—neglecting magnitudes of fourth and higher order—by 1/2 v2/c2."
This effect must be valid in general: not only mechanical clocks slow down by a factor γ but any natural process, including the half-life of radioactive "clocks" such as muons.
Note also that the expression "viewed in the stationary system" is the reference for "laws of physics"; it's not a transformation equation, and universal can use that law for arriving muons with the Earth as "stationary system".
  • #242
A transformation changes numbers in one coordinate system into the equivalent numbers in another system. If you have first calculated the number in the muon frame, you can use a transform to convert any frame-dependent numbers (e.g. lengths and times) to the Earth frame. The number of muons reaching the Earth is an invariant so applying a transform will not change it.
Physics is nothing but mathematics applied to measurable quantities. The basic physics we are using has been posted several times, it is the exponential equation which predicts the number of particles that decay in a given period based on the half-life of the muon. That equation is obviously just mathematics.
Using a transform simply converts that half-life to a different coordinate system.
No, I doubt that you have grasped that the question you are asking is the same as querying the "physical cause" for taking more strides to get from A to B via C than going directly from A to B. Most people think of that as a consequence of geometry rather than a "physical" effect but your definition of what you mean by "physical" is different to what I have seen before.
  • #243
See my post #207, Which shows very clearly, that you are just juggling mathematics... and by NO means it can be said a derivation.
  • #244
No, you're wrong. The gamma factor emerges from the Minkowski metric with a simple rearrangement of the differentials. You cannot deny this - it is elementary mathematics.
  • #245
Post 207 doesn't show anything "very clearly". And yes, as Mentz114 mentioned, my post 154 derives gamma without a coordinate transformation.
If you choose to call a correct derivation "just juggling mathematics" then so be it. It is still a correct derivation and completely refutes your claim.
